Calculating resistance of an oxygen probe
The discussion focuses on estimating the life of an oxygen probe used in a heat treating furnace by calculating its resistance at high temperatures. A new probe typically has a resistance of 10-15K Ohms, and nearing 25K indicates imminent failure. The user is attempting to validate a formula for calculating probe resistance based on millivolt readings before and after applying a known shunt resistance of 50K Ohms. The key assumption in the formula is that the current remains constant in both scenarios, which is under scrutiny. The user seeks clarification on the validity of this assumption and alternative methods for resistance calculation using the millivolt output.
dstanton
I have an oxygen probe that produces a millivolt reading once it reaches 1500F based on the parts per million of oxygen in a heat treating furnace.
The life remaining in the probe can be estimated by the resistance it inherently has at this temperature. A new probe has about 10-15K Ohms and once it gets close to 25K it is going to fail soon.
Anyway, I have this probe hooked up to a PLC analog input card continuosly reading millivolts (roughly 1000-1200) as a process controller. I was told to run a test once a day to determine and log the value of the probe impedance. The guy before me is doing this by using a digital output to shunt the probe with a known resistance 50K Ohms and comparing the before and after millivolt readings.
I have spent the last 2 hours trying to prove (or disprove) the formula that he is using to calculate probe resistance from these two voltage readings. The formula is:
Rp = ((Vp/Vt)-1)*50K where Rp is the probe resistance, Vp is the probe millivolt reading, and Vt is the milliVolt reading with the shunt active
I was able to derive this same formula using Ohms Law, but I had to make one assumption...that the current was the same in both situations.
Questions:
1. Is it an accurate assumption about the current being the same in both the standard scenario and the shunted scenario?
2. If not, is there another simple way to do this by using resistance and the millivolt output?
Any help you can give me would be very much appreciated!
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
