Calculating ∆rH° for Cu + O2 -> CuO
  • Thread starter Thread starter Diamond101
    Thermodyamics
The discussion focuses on calculating the standard enthalpy change (∆rH°) for the reaction Cu + O2 -> CuO using provided thermodynamic data. The initial calculations show that ∆rH° for the reaction at 298 K is determined to be -155.1 kJ/mol. For part (b), participants discuss how to calculate ∆rH° at 1000 K using the heat capacities (Cp) of the substances involved. There is confusion regarding the correct application of the equation ∆H(T1) = ∆H(T2) + CpΔT, with some participants questioning its dimensional accuracy. The thread emphasizes the importance of ensuring proper unit consistency in thermodynamic equations.
Diamond101
1. (a) From the following data, 2 Cu (s) + S (s) Cu2S (g) ∆rH° = - 79.5 kJ mol-1 S (s) + O2(g) SO2 (g) ∆rH° = - 296.8 kJ mol-1 Cu2S (s) + 2 O2(g) 2CuO (s) + SO2(g) ∆rH° = - 527.5 kJ mol-1 Determine ∆rH° for Cu(s) + ½ O2 (g) CuO (s) at 298 K
(b) Given the following Cp / (J K-1 mol-1) Cu(s) = 24.44 O2(g) = 29.36 CuO (s) = 42.30 Calculate the ∆rH° for the reaction at 1000K.
More so part b is it correct
2 Cu (s) + S (s) ---> Cu2S (g) ∆rH° = - 79.5 kJ mol-1
SO2 (g) ---> S (s) + O2(g) ∆rH° = +296.8 kJ mol-1
Cu2S (s) + 2 O2(g) ---> 2CuO (s) + SO2(g) ∆rH° = - 527.5 kJ mol-1
Adding the above three equations results in this:
2 Cu (s) + O2(g) ---> 2CuO (s) ∆rH° = -310.2 kJ
Dividing through by 2 = -155.1 kJ.
part b cu(s) =+79.5 =24.4 (1000-298 k) using the equation ∆rHT2=∆rHT1+∆CP(T2-T1)
SAME GOES FOR O2 and CUO ?
How did you get the last equation? ΔH(T1)=ΔH(T2) + CpΔT ?
actually i got Δcp= cp products -reactants= 43.3-24.44+0.5*29.36)= 3.18 kj/mol
ΔHr 1000= ΔHr 298+ΔCpΔT
-155.1*10^3 J-MOL * 3.18 JK-MOL *702 K
=-155.1 *10^3 + 2232.36
= 152.9 KJ/MOL
And the equation was my lecture notes
= 152.9 KJ/MOL
Check the equation once again. It is dimensionally incorrect.
Cp has units J K-1 mol-1 while ΔH has units J mole-1
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
