BitWiz
Hi,
Say I have a spaceship in ideal gravity-free, friction-free space. I have a source of power capable of producing a maximum of E joules per second, and I want to use some form of continuous electric propulsion, such as a Gauss gun or ion thruster, to get around.
I have these questions:
1) From the spaceship's frame, how do I calculate the ship's acceleration from E, given the ship's Lorentz-adjusted mass, the mass of projectiles fired per second, and any other required parameters? An equation would be very helpful, along with an example using simple values such as 1 second, 1 kg, 1 meter, etc.
2) Does the projectile's actual rest mass and final velocity really matter in calculating the reactive force F' that accelerates the ship? If the gluons will put up with it, can I theoretically accelerate a single proton in a Guass gun fast enough to produce an F' that accelerates a (very sturdy) ship to any Lorentz gamma in one ship second? In other words, given perfect engineering, can I directly translate any power to acceleration without regard to the speed-of-light c in the Gauss gun, simply because the projectile's effective mass will always adjust to balance momentum, relative to the ship?
3) As the Gauss field "pushes" the projectile, does the field itself change in a Lorentzian and/or Doppler way from either the projectile's frame or the ship's frame, that reduces the ability to continue to apply force to the projectile? For instance, if the projectile is traveling too fast to see changes in the field propagate from the source, does it still see the field at all?
4) How does the projectile appear to me (in the ship)? Does it seem to slow down as relativistic effects become conspicuous? If I manage to accelerate it to very close to c, does it ever leave the gun?
5) Finally, if I accelerate a proton to c minus one-zillionth (or so), does the proton become a black hole from my frame, ie does the Schwartzschild radius expand to encompass the boundary of the particle? Would it know it? How about for larger masses? To me, would the black hole appear virtually stationary?
Thanks very much.
Bit
Thanks very much.
Bit
