Calculating Sliding Friction Coefficient (μ) for Car on Icy Road
  • Thread starter Thread starter lim
    Friction Sliding
The discussion revolves around calculating the coefficient of sliding friction (μ) for a car skidding on an icy road. The car, weighing 2090 kg and traveling at 22.2 m/s, comes to a stop after sliding 64.9 m, leading to the calculation of acceleration as -3.796 m/s². The correct formula for μ is derived as μ = a/g, resulting in a coefficient of friction of 0.378. Clarifications are made regarding the use of force equations and the interpretation of negative values in the context of friction. The final conclusion is that the coefficient of friction is 0.378, emphasizing the importance of considering only positive values in this calculation.
lim
You are driving a 2090 kg car at a constant speed of 22.2 m/s along an icy, but straight and level road. While approaching a traffic light, it turns red. You slam on the breaks. Your wheels lock, the tires begin skidding, and the car slides to a halt in a distance of 64.9 m. What is the coefficient of sliding friction (μ) between your tires and the icy roadbed?
vf^2=vi^2=2ax
F=ma
vf^2=vi^2=2ax
0= 22.2^2+2a64.9
a=-3.796 m/s^2
F= sum of forces/ W
= -3.796(2090)/2090(9.8)
= -.387
help appreciated
Frictional force = (mu)*N, so (mu)= F/(mg)
Why have you written F= sum of forces/W?
What is actually the magnitude of that thing which you are calling F?
It meant sigmaF=ma/mg. I put w, becuase w=mg. The magnitude of F, force was 3.796(2090)=7933.64 N. Is my method incorrect? I was trying to find the acceleration and use F=ma, and then I use (mu)= F/(mg).
Sum of forces = ma. That's all. Here, F=ma, where F is the force of friction.
ma= F= (mu)N = (mu)W = (mu)mg.
So, (mu) = (ma)/(mg) = a/g.
What you've found is the value of the co-eff of friction, with a -ve sign.
Just for understanding, Why isn't the value negative or why would it be the magnitude? Is it because friction is slowing down so it would always be a negative number?
The co-eff of friction is defined to be the ratio between the magnitudes of the frictional force and the normal reaction. So, we’ll consider only the positive value of the frictional force, and so the co-eff will always be a +ve number.
Upto finding ‘a’, you were correct. After that, you have written F= sum of forces/w, which is wrong.
What you should write is (mu)=F/N=ma/(mg)=a/g=0.378.
(Unknowingly, what you have calculated is nothing but Force/Normal Reaction, so you have actually calculated the value of the co-eff itself. But you have taken the force to be negative. That’s why I said it’s that value with a –ve sign.)
The answer is that the co-eff of friction is 0.378.
Is it clear now?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
