Calculating speed of specific Rising Gas
The discussion focuses on calculating the rising speed of hydrogen gas in air after electrolysis, with an emphasis on how variables like cylinder diameter, height, and air temperature affect this speed. The original poster seeks an equation for this calculation and is also interested in how the speed might change if a heavier gas is used instead of air. Participants note that there are no simple formulas for gas mixing scenarios and suggest using simulation software to approximate flow rates. The conversation highlights the complexity of gas dynamics and the need for specific boundary conditions in simulations. Overall, the inquiry points to the challenges of accurately modeling gas behavior in different environments.
KyleKidd
Hello everyone. I am a college graduate perusing independent research of my own. I'm trying to figure out how to calculate how fast a specific gas (hydrogen) will rise from an initial velocity of 0 in room air and temperature.
Basically, I'm trying to figure out how fast hydrogen would be traveling as it rose in a cylinder after electrolysis per given distance (do gasses reach terminal velocity?).
Also, it would be helpful to be able to calculate the speed in a heavier gas if my experiment called for using a more inert gas.
Is there an equation for calculating the speed of a rising gas? Despite my best effort, I cannot find any material on it. Perhaps I am using invalid search parameters. Any help?
Welcome to the PF.
Since you mention electrolysis, should we assume that you are asking how fast the hydrogen and oxygen bubbles rise through the water at the bottom of the tubes?
Thank you for the warm welcome.
Your assumption would be incorrect. I am interested in how fast hydrogen would rise in air. The only reason I mentioned electrolysis was for context.
Basically, I want to know how fast I could expect hydrogen to rise straight upwards if confined to a cylinder of room air.
The diameter of the cylinder, height of measurement, and air temperature would all be great variables to include in the equation I'm looking for.
Also, I may be interested in substituting normal atmospheric air with a heavier elemental gas. Possibly to increase buoyancy of the hydrogen as it rose, or to substitute air with a less reactive gas.
Bubbles in a liquid would probably be easier, but in the general case, maybe not.
Can you say more about what you want to simulate? There aren't any simple "formulas" for general cases of mixing gasses. You would usually use simulation software to try to approximate those flow rates.
What are the boundary conditions? What laminar flow / FEA simulation software do you have access to?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
