Calculating strength gravity over light years
To calculate the strength of gravity between two objects that were initially 2 light years apart and became 0.5 light years closer, one must consider their current mass after losing 50% due to fusion and light. The gravitational force can be calculated using Newton's law of gravitation, which requires the current mass and the distance between the objects. The discussion highlights the importance of determining whether to use the mass from two years ago or the current mass for accurate calculations. The choice between these two approaches depends on the specific context and requirements of the calculation. Understanding the implications of mass loss over time is crucial for accurate gravitational strength assessment.
ensabah6
How do I calculate the strength of gravity between two objects say that 2 years ago were 2 light years apart, during which they became 0.5 light years closer, if during those two light years, the stars lost 50% mass due to fusion and light,
based on their mass "now", or based on how much mass they had 2 years ago,
Astronomy news on Phys.org
That is a Relative question. Which do you want or need to know?
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
