Calculating the filter capacitor for a power supply
2 replies · 4K views · last reply
TheRedDevil18
Trying to build a simple 9V power supply using a 7809 voltage regulator and full wave rectifier. The load current from the regulator is 1A. So I = C*dv/dt, therefore,
C = I*t/(delta V)
To my understanding t is the time between the two peaks or the time the capacitor supplies the load. So if t is reduced, shouldn't the ripple increase ?, so isn't ripple (delta V) dependent on t ?, if so then why is delta V just arbitrarily chosen without considering t ?
1, t is fixed if you are using mains power - at roughly 0.01sec.
2, ripple would increase with t, if you were using a variable frequency supply.
This should be clear from the graph. If the peaks are further apart, the output drops more between peaks.
3, I don't think delta V is arbitrarily chosen. It comes from the permissible ripple. You know delta t, from mains frequency, and I from your spec. Then you calculate C.
Permissible ripple may come from the difference between, the lowest operating voltage of your regulator and the peak value your capacitor charges to.
look at your graph
solve for dv
dv = I/C X dt , therefore
increasing Δt increases Δv
you knew that, just you were in a hurry. Think in small patient steps.
