Calculating the force required to generate 100 kilowatt per hour
  • Context: Undergrad
  • Thread starter Thread starter Jaxodius
    Force Per
The discussion revolves around calculating the physical force required at a specific point to generate 100 kilowatts of power using a mechanical system involving gears and an alternator. Participants explore the relationship between power, force, and rotational speed, while addressing misconceptions about units of power and energy.
  • One participant seeks to understand how much force is needed at point B to generate 100 kW, given a gear system that increases RPM at point A.
  • Another participant emphasizes the need for a specific rotational speed to calculate the required force, providing an example calculation based on 1 revolution per second.
  • Confusion arises regarding the correct interpretation of power and energy units, with one participant mistakenly using terms like "kilowatts per hour."
  • Participants discuss the implications of using different gear ratios and how they affect the force and power output, with one suggesting a complex gear setup to manage force application over time.
  • Clarifications are made about the difference between power (watts) and energy (joules), with participants attempting to reconcile their understanding of these concepts.
  • One participant expresses a desire to conduct practical experiments based on their calculations, while another warns about the importance of understanding the correct units of measurement.
There is no consensus on the correct understanding of power and energy units, with multiple participants expressing confusion. Some participants agree on the need for clarity in definitions, while others continue to struggle with the concepts.
Participants highlight limitations in their understanding of the relationship between power, force, and energy, as well as the importance of using appropriate units in calculations. The discussion reflects varying levels of familiarity with these concepts.
This discussion may be useful for individuals interested in mechanical systems, energy generation, and the principles of power and force in physics.
Jaxodius
Hello to everyone,
I am trying to calculate how much physical force is needed at point B (imagine a person pushing on a bar attached to point A) to generate 100 kw per hour where the radius is 50 meter. If you imagine that at point A there is a system of gears attached to an alternator/generator which transforms 1 rpm from point B into 3600 rpm at point A(4 gears with a gear ration of 15:1 between them), how much force would be needed to generate 100 kilowatts per hour? I understand there will be friction, but at the moment i am just trying conceptualize how much physical work is needed to generate that amount of power.
This is the first time i am trying something like this so if i have made any wrong assumptions, please correct me.
You need to give us more information.
Power is work done per unit time. So 100 KW is 100 KJ per second = 100,000 Nm/sec.
In order to determine how much force is required to generate such power, you have to tell us how fast you want to make the bar rotate. For example, if you want to generate 100 KW at a rotation rate of 1 revolution/second (ie. B moves 2∏R = 314 m. in one second) then you would need a force of 100,000/314 = 318 N.
AM
Thank you Andrew. you raise a very good question:
[1] i am not sure weather to generate 60 kilowatts per hour ( i am simplifying the numbers so i can understand easier but my actual project is for 100 kilowatts per hour ), if one needs to generate 60 kw per second or 1 kw per minute?
[2] Also, the way i visualize it in my mind, is that a person will have to be applying 318 Newtons per meter for 314 meters to make 1 revolution. is this correct? if so, do i use the 60kw/sec or 1kw/min to calculate the force i would need.
You are confusing yourself by talking about "kilowatts/sec" and "kilowatts/min"; those terms make no more sense than something like "miles per hour per day". Power, measured in watts, is not an amount of work but the rate at which that work is delivered: one Joule of work per second is one watt.
Your problem is asking for 100 kw, meaning that it will deliver 100,000 Joules/sec for as long as it is operating, and it will take some force in Newtons to do this. Obviously the longer it operates the more total joules it will deliver, but the force in Newtons will be the same; it'll just be operating for a longer time.
Thank you Nugatory. I think i really am confusing myself more. let me explain what it is i want to do. i have an oven that is rated at 100 kWh and it need to run for 3 hours. I am trying to determine how much force would be needed to provide 100 kWh to that oven using the set-up i mentioned in my first post ( 4 gears with 15:1 gear ratio attached to a bar with the length of 50 m ).
Clearly i cannot do 314 m in 1 second :smile: so i was thinking what if i added more gears so that instead of providing the 318 N force per 1 revolution of point B, i provide it over 1/60 of that one revolution. Therefore :
3600 rpm * 60 = 216000 rpm . If i used 6 gears with ratio of 15:1 between 5 of them and 5:1 between 1 of them making it a total of 253125:1 and then proceeded to make 1 revolution from point , will i be providing the same power every second of that revolution? I know i cannot do 314 meters in 1 minute either lol but am i thinking about this the right way? or is there another way to spread that much force and still provide 100 kw/s?
You're still confusing power (watts) and energy (joules) here. 100 kWh is a measure of energy. It's the amount of energy a 100 kw power source delivers in one hour, or a 10 kW source delivers in 10 hours, or a 1 kW source delivers in 100 hours. If you remember that there are 3600 seconds in an hour, and one watt is one joule per second, you'll see that all of the above combinations come out to the same amount of energy, 3.6x108 joules, whether it's a little power delivered over a long time or a lot of power delivered over a short time.
(100 kW is also a LOT of power... It's about 130 horsepower, and I suspect that you're misreading the specs of your oven).
Yes, you're thinking about it the right way now: as long as you're maintaining a constant speed and force you're delivering a constant power. But notice that this doesn't change if you play with the gearing or the length of the lever arm; all that does is make it so you're applying the same force over a different distance and (because your speed is constant) a different time, so applying the same amount of power for a longer time and doing more total work.
You're also quite right that you can't do 314 meters in one second - as I said above, 100 kW is a lot of power.
Thank you for your prompt and very helpful reply Nugatory. After doing some excel calculations i think i understand it enough to start with some practical experimenting.
Thank you both for your help. I consider this problem solved.
I'm afraid the problem will not be solved until you understand what the real units of power and energy are. Under even the mildest of scrutiny, what you are writing makes no sense. It would not take too much of your time to learn how to use the appropriate units and it would help so much more for your credibility.
It really does matter.
Just for emphasis:
There is no such unit as "kw per hour" or "kw per second". I don't believe you understand that yet either, so I'm relatively certain you have not calculated anything of value yet.
Sophie please let me know if my understanding of power and energy is still wrong:
Example: when i use a 1kw AA cell in my phone that has the ability to use either 1 watt or 1000 watts every second it is turned on, the 1kw AA cell will either last 1000 seconds or 1 second depending on the amount of energy it draws. So the power in the 1kw AA cell can last depending if the energy drawn by my phone is 1 watt / sec or 1kw/sec.
Power= 1 Kw and Energy= 1kw/s or 1w/s
I spoke to nugatory in pm after his last message because i was getting embarrassed and wanted a clarification. it was after his reply in pm, which clarified things a bit more, that i made my last post.
I want to quote you something from http://physics.nist.gov/cuu/pdf/sp811.pdf page 24 which reads:
Reference [4: ISO 31-0] suggests that if a space is used to indicate units formed by multiplication,
the space may be omitted if it does not cause confusion. This possibility is reflected in the
common practice of using the symbol kWh rather than kW · h or kW h for the kilowatt hour.
So are you wrong or are you talking about something other than what is mentioned on that page? because when i use the term kwh, i mean x kw per hour. please clarify.
As for not calculating anything of value, i was able to calculate how many people i would require to use x amount of force over x amount of distance to make the whole thing realistic. so for me, it was very valuable.
Replace every instance of watt with joule and it is mostly correct.
Understand that kW*hr (kilowatt-hours) is not the same as kW/hr (kilowatt PER hour). One kilowatt-hour is a unit of energy, and is equal to 3600 kilojoules (1 kW * 1 hr = 1 kW*hr). Kilowatt/hour represents something entirely different. Physically, a kilowatt per hour would be a rate of change of power, for example the ramp rate of a nuclear reactor (which typically have limits on how fast they are allowed to change the power level due to material constraints).
The unit of power is indeed Watt (W), or kW = 1000 Watt.
The units of energy is Joule or Watt-second and NOT Watt per second.
A You gett one Watt-second by producing one watt for a second. (or 2 watts for a half second etc.)
You have energy = power * time, E = P T here, and because the units of power is watt, the unit of time is seconds, the unit of energy must be watt second.
You use "per second" in a unit for a rate of change, for example speed,
which has unit meters per second. you have speed = distance/time, we divide here instead of multiplying, and that's why you have m/s or meters per second, and NOT meter-second.
The capacity of batteries is usually given in Ampere-hour, If you multiply this by the voltage you get watt-hours. You're talking about a 1 kW AA cell as if this is the capacity of the battery, but kW is a unit of power. 1 kW would drive a vacuum cleaner, and is a few hunded times the maximum power a phone would use, or that an AA battery could deliver.
I think it would help if, instead of hanging on to your particular version of this, you started way back at the beginning and stuck with the definition of Energy and Power that everyone uses. Some of the figures you are calculating are correct (by chance, because some errors are sort-of cancelling out) but your thesis is just flawed. If you cannot see what you are doing wrong then you have to believe that you are wrong and find out, for yourself, what the problem is.
Start with the definition that Energy is Power TIMES time and that Power is Energy PER unit time.
Jax, a kWh is kw TIMES hours, not divided by hours. So you actually have two errors here, not one:
1. You don't know what a kWh is.
2. You shouldn't be using it anyway.
Just about everything you've posted should be about power, not energy. kW - just kW - not kWh, not kw per hour, not kWh per hour. Just kW.
Now perhaps you got lucky and your errors canceled each other out, but it is more likely you got the wrong answer.
Just for info... What will be applying force on the bar?
i believe a fit human can generate about 1/3rd of a horsepower (eg 250W) for sustained periods. If you need 100kW that's quite a team of people you will need (400 people).
I read somewhere that to produce one horsepower (750W) you actually need 1.5 real horses (so 200 needed). I've no idea if they can keep that up for three hours though.
PS: Insulate the oven better. They will thank you for it.
Thank you sophie, i will keep that in mind.
CWatters i was planning on hiring people to do it because it will only be for 3 hours. and you are right it will be about 400 people. I was thinking that maybe i can divide them into groups and 1 group takes over another.
Honestly, hiring people is not a problem. i am more concerned about the 6 gears with a ratio of 15:1 between them. is a gear system like this even realistic? what kind of problem can arise?
What is the purpose of your giant human-powered generator? Hiring 400 people for 3 hours at $10/hr would cost $12,000. I did some googling and found that you could rent a 100 kW generator for a day for $500.
It does not take $10/hr to hire someone in china or India :)
Do you think the gears will hold up?
Jaxodus;
From just a mechanical perspective. A 50 meter lever seems somewhat excessive. And your discussion of running an oven, and then running a cell phone with a 1kw AA battery does not add to the clarity at all. Besides it would be more instructive if you first told us about the generator, and the rating of same. Irregardless of the gears and the lever used to drive the generator, the power availability would depend on the capabilities of the generator itself. Whether or not the lever and gears can deliver the necessary torque to the generator does not depend on the weather. Sorry, as I have been taken to task for my language and use of same, I may as well make my own observations. Nothing personal!
Thank you jeffery. and please do not hesitate to point out any wrong assumptions i have made (as i said in my first post ). this will be my first attempt at anything like this and i would like to get it right. and to clarify, the project is for 100 kw-second ( thank you willem2 for clarifying this ) but i gave the example of the cell phone just for sophie. i know there is no 1kw AA battery lol
This is the item i had in mind to attach the gear to at point A ( diagram in the first post ). only instead of using fuel, i wanted to calculate the force required to do it manually:
http://www.engine-trade.com/product/cummins-200kw-diesel-generator-set-for-landuse.htm
It has all the details. i would post them here but it would look like a huge spam. at the moment i am not even sure how i would attach the gears to this but it cannot be absolutely impossible.
I think it's going to be a challenge connecting 400 people to a shaft in such a way that they can all deliver 250W. You need to do more research because I think 250W is the figure for cycling at near ideal cadence (eg most comfortable pedal rpm) and it might be a lot lower for pushing or pulling on a lever.
Worth watching...
Took 78 cyclists to power an electric shower which is probably 8-10kW.
If you assume 400 people can be connected to a 50m lever and are jogging along at 5mph somehow delivering 250W each then the angular velocity of the shaft works out at about 0.044 radians/second and the torque about 2.2 * 10^6 Newton meters. Nearest thing I can think of to something like that is probably a wind turbine but they rotate slightly faster and lower torque.
Jaxodius said:
...and i would like to get it right. and to clarify, the project is for 100 kw-second...
I doubt it. That's 100 kW for 1 second or 1 kW for a minute and a half. About as much energy as having a lightbulb on while you eat dinner.
It sounds from other posts (as others have gleaned) like you have a 100 kW load that you want to power for 3 hours. That's 300 kWh.
I think the estimates other people are giving on the amount of power you can extract from humans is too high because you aren't talking about athletes but normal people. I expect you'll need at least a thousand.
In addition, the 100kW number sounds extremely high - unless it's some kind of industrial oven or similar, chances are that the real power draw is much smaller.
I was thinking of having 4 arms/levers attached to point A in such a manner that they form a plus sign. then i can have 50 people per arm. Infact, as the discussions have progressed, something else comes to mind. what if the 250w per person was directed to raise an object which was 5000 kg / m3, such as hematite ( iron ore which is 5095 kg/m3 ) and had 10 m3 of it raised to 100 meters ( it does not strictly have to be raised above ground, it could just as well be pulled up from a shaft dug 100m into the ground. This is the calculation i made. please tell me if it is wrong:
10 m3 blocks of hematite ( 1 on top of another ) = 50000 kg m3
(so 50000 (weight) * .028 m/s (to allow the blocks to fall in 1 hour as 100 meter / 3600 seconds ) * 100 (height)) / 1000 (to convert it into kw ) = 140 kw-s.
Is this correct? using this, for one hour i would be getting 140 kw-s for every second the weight falls?
That is correct.
my understanding is that, if i increase the length of the lever to 100 meters, i would have not have to use the same force but only work longer. honestly, as long as i get 300 kwh to discharge every 24 hours, i do not care if it takes 8 hours to get this done.
cji you are correct, it is an industrial oven.
russ_watters said:
Just for emphasis:
Well, I don't know about you, but I pay a certain amount of cash for KW hours. When I have used a KW in an hour, I pay for the going rate of a 'KW hour. A sixty watt light bulb uses sixty watts every hour. This system for AC use is dependent on the specific cyclic rate of the current. Which, where I use AC is 60 hertz. It's a good thing for AC timepieces also, as in clocks. In fact a watt hour meter is just that, a clock that instead of having hour and minute hands, has a series of dials that are base ten, I believe--at least the old ones were before the move to digital.
In electricity; Power, is a function of the induction and the energy potential. Also, Energy potential is a function of induction and resistance. Don't bother refuting Mr Ohm sir. I did not make the preceding up in a fit of Mania, or Asberger-ity either.
24 hours? 8 hours?
1. How are you going to store the energy if the oven is only running for 3 hours?
2. It still means multiple shifts. Still a larger number of people, just not all at the same time.
jeffrey c mc. said:
Well, I don't know about you, but I pay a certain amount of cash for KW hours. When I have used a KW in an hour, I pay for the going rate of a 'KW hour. [emphasis added]
You don't use "a kW in an hour", you use a kW for an hour to get a kWh.
No it doesn't. It uses 60 Watts all the time, or 60 watt-hours every hour.
Russ; yes I think I see my error. Thanks for the correction. In the case of the light-bulb perhaps I should say enlightenment. Oh yeah, I went there, I did.
This is completely silly. If it made any kind of economic sense to generate power this way then power companies would be generating it this way.
A kWh costs about $0.16 and since a human's maximum sustained output is 250 W that is at least 4 man hours. Since nobody will work for anything even remotely approaching $0.04 per hour (not even in China or India) it will cost you far more to make power this way than to simply buy it.
  • · Replies 74 ·
11K
  • · Replies 17 ·
  • · Replies 32 ·
