Calculating the moment of Interia
  • Thread starter Thread starter PenTrik
    Moment
The discussion centers on calculating the moment of inertia Ixx for a specific region defined by the equation y = h(x/b)^2. The initial attempt led to an incorrect result of h^3*b/7 instead of the expected h^3*b/21, indicating a potential oversight in the integration process. Participants suggest setting dA as dydx and evaluating a double integral with appropriate limits for x and y. Clarifications on the limits and the correct form of the equation helped the original poster understand the solution. Ultimately, the collaborative effort led to a successful resolution of the problem.
PenTrik
Prove that the moment of inertia of the same region about the x-axis, Ixx, is given by bh^3/21
where y = h(x/b)^2
\int(y^2*dA)
so I first figure that dA has to equal
h(x/b)^2 * dx
and that y has to equal
h^2 * (x/b)^4
so when I put it into the intergral, I get something along the lines of
\int(h(\frac{x}{b})^2 * h(\frac{x}{b}) ^ 2 * h(\frac{x}{b})*dx)
from 0 to b
except when I calculate it out, I get a solution of
\frac{h^3*b}{7}
instead of
\frac{h^3*b}{21}
somehow I am missing a 1/3.
if it at all helps, I've already calculated the centroids to be <0.75b, .3h>
Set dA = dydx and evaluate a double integral over the given region (you have the limits of x as well as y). Remember to first evaluate with respect to the variable limits (your "inner integral") and then with respect to constants (your "outer integral" should have constant limits). That will give you the right answer. :smile:
Ah uh, would my limit for dx be from 0 to b, and for dy to go from 0 to y=h(x/b)^2?
PenTrik said:
Ah uh, would my limit for dx be from 0 to b, and for dy to go from 0 = y=h(x/b)^2?
Think you made a typo (should be h(x/b)^2) but that is exactly right :smile:
EDIT: As I was replying, you fixed it :biggrin:
Holy ****, I get this now.
Thank you much.
HAHAHA! Glad to be of help! You see, you can do it :wink:
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
