Calculating the Power and Impact of Black Body Radiation from the Sun
To calculate the power radiated by the sun, use the Stefan-Boltzmann law, which states that power per area (P/A) equals Stefan's constant multiplied by the temperature in Kelvin raised to the fourth power (P/A = σT^4). The sun's temperature is approximately 6000 K, and its radius is about 700,000 km. To determine how much of this power reaches Earth, calculate the Earth's cross-sectional area and divide it by the surface area of a sphere centered at the sun. Stefan's constant is 5.67x10^-8 Wm^-2K^-4. This approach will yield the total power received by Earth from the sun.
scissors
My problem is that I have the numbers...but I don't have a formula.
"The sun's temp. is about 6000 K, it's radius 700000 km. How much power is it radiating? If there is no dissipation between here and the sun, how much of this hits the earth?"
Is this the P = c/4*U thing?
I'm not sure what equation you are referring to. You have to use the Stephan-Boltzman law for blackbody radiation:
P/A = \sigma T^4
where P/A = Power/Area, \sigma is Stephan's constant and T is the temp. in K.
Then work out the cross-sectional area of the Earth and divide that by the area of the surface of a sphere centred at the sun and intersecting the earth.
AM
In case you don't know - Stefan's constant is equal to 5.67x10^-8 Wm^-2K^-4
Ah, I see. Thanks a lot guys!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
