A Calculating the power spectra of scalar perturbation
The discussion focuses on calculating the power spectra of scalar perturbations during warm inflation, specifically at the Hubble crossing. The participants explore how to determine the quantities at the horizon crossing, emphasizing the relationship between the scale factor and the Hubble parameter. They discuss the need to plot the relationship between k and N to identify when k crosses the horizon, which is crucial for calculating the tensor-to-scalar ratio. Numerical methods for solving the mode equations are suggested as a way to obtain the power spectra without relying solely on slow-roll approximations. The conversation highlights the importance of understanding the mapping between physical scales and e-foldings in the context of inflationary models.
shinobi20
I'd like to numerically calculate the power spectra of the scalar perturbation at the Hubble crossing in warm inflation, my problem is that I don't know how to do it. As I know, the Hubble crossing happens at the onset of warm inflation where the different modes become larger than the Hubble length. Now suppose I have solved the dynamical equations of warm inflation with respect to time. So given the scalar power spectra at the Hubble crossing,
$$P_S = \Bigg( \frac{H_*}{\dot\phi_*} \Bigg)^2 \delta\phi_*^2 = \Bigg( \frac{H_*}{\dot\phi_*} \Bigg)^2 \Bigg(\frac{\sqrt{3(1+Q)} H_*T_*}{2\pi^2}\Bigg)$$
where ##H## is the Hubble parameter, ##\phi## is the inflaton field, ##T## is the temperature, and ##Q = \frac{\Gamma}{3H}## is the ratio of the effectiveness of the dissipation ##\Gamma##. The "##_*##" denotes the quantities are evaluated at the horizon crossing.
How do I solve for the quantities AT the horizon crossing? Can I plot out an evolution of some quantity and identify that at some point on the plot, that is the horizon crossing? Or how should I proceed in solving this? Does anyone know of any resources/ material that I can look into to be able to know how to do this?
Space news on Phys.org
What is the condition for horizon crossing in warm inflation? In standard inflation it's k = aH.
As I know, it is the same thing. But let's assume that we are in the cold inflation case. I know that we should evaluate those quantities at the horizon crossing, but these are just all statements, how do I actually do it i.e. plotting it out or determining when is the Hubble crossing from the plot of something.
The power spectrum for the scalar perturbations in the cold inflation case at the Hubble crossing is given by,
$$P_S = \Bigg(\frac{H_*}{2\pi}\Bigg)^2 \Bigg(\frac{H_*}{\dot\phi_*}\Bigg)^2$$
What are you trying to do, determine P(k)?
Yes, in order to get the tensor to scalar ratio.
You've got two relations: the power spectrum and the horizon crossing condition. The expression for P can be solved in terms of some time variable, pick one (a, t, N, ...), as can the expression k = aH. The idea is to solve for the power spectrum at horizon crossing parametrically.
I understand what you mean by solving P and k in terms of say, N; so I need to plot k=aH with respect to N and tell from the plot where is the horizon crossing?
Once you have k = aH as a function of N, you can obtain P(k) parametrically.
So I first need to know when k =aH from the plot of k vs. N right? But what is k? There isn't an explicit expression for k.
No, you're plotting k = aH, say, as a function of N. This function tells you the value of k that is crossing the horizon at the corresponding value of N.
But that is my question originally, suppose I plot k=aH as a function of N, how would I know when IT crossed the horizon?
What is IT? You have k vs. N. Pick an N. The associated k is crossing the horizon at that N. I think we're talking past each other...
Oh, what I mean by IT is ##k##. So if I plot ##aH## as a function of ##N## and from observation we need at least ##N=60## of e-folding for the duration of inflation, then the corresponding ##k## crosses the horizon? But that would just mean if say, I plot ##H## vs. ##N## and just choose whatever ##H## is at ##N=60## that would be the corresponding ##H_*## at the horizon crossing, as well as for ##\dot\phi_*##.
Yep. There is just one k that crossed the horizon at N = 60. But you said you wanted P(k), so presumably you are interested in the spectrum at more than just N = 60, right?
Wait wait, maybe what I'm thinking needs some patching. Basically I want to numerically compute the tensor to scalar ratio without using the slow roll parameters. So, the tensor to scalar ratio is given by ##r = \frac{P_T}{P_S}## where ##P_S## is the power spectrum for the scalar perturbations, while ##P_T## is the power spectrum for the tensor perturbations. I just showed ##P_S## in the op since if I know how to do it in ##P_S##, ##P_T## would follow. So, based on what I know ##r## is calculated at the instant ##k## starts leaving the horizon (indicating that the slow roll inflation started, not inflation); this is usually denoted by ##N=60## before the end of inflation. So I think what I need is just ##P_S## at the onset of slow roll inflation not the whole spectrum even during inflation? Is this correct?
A few things. If you wish to compute r without reference to slow roll, you can't use the expression you posted for P_S, since it is lowest-order in slow roll (specifically, the quantity H/2\pi). The only way to do this in general is to compute P_S and P_T by solving the mode equations numerically, across a range of k. But, assuming you wish to use the slow roll expressions for P_S and P_T, then to get r at, say, the CMB quadrupole, you would evaluate r = P_T/P_S at N = 60.
Oh... So what I usually see in cosmology books and some in the literature are approximations for ##P_S## and ##P_T##. So how would I go on to numerically solve the mode equation to get ##P_S## and ##P_T##? Do you know of any reference/papers that detail this method?
In the literature, is it often the case that physicists just use the lowest order approximation for ##P_S## and ##P_T##? What justification did they consider?
Yes. In fact, I did this for my thesis ;). See this paper for a discussion of the numerical solution: https://arxiv.org/pdf/0706.1982.pdf. In that work we had a weird way of including the background cosmology in the mode equation (basically, we did Monte Carlo over inflationary solutions described in terms of Taylor expansions of the Hubble parameter, the so-called flow method). You probably won't set your problem up this way, opting instead to solve the mode equation along with the Klein Gordon equation for a specific potential and initial condition on \dot{\phi}. I've done it this way too, but haven't published the code anywhere. That said, the above reference might still be useful for its discussion of how to intialize the mode functions and how to build P(k) from individual solutions. That stuff is necessary regardless of how you are thinking about the background, but I'm happy to provide any insights on how to do the solution with the KG for specific potentials.
As for the literature, the lowest-order expressions are often used because authors are often working in the slow roll limit, or close to it. There are higher-order approximations to these results (papers by Stewart and Lyth come to mind, e.g. https://arxiv.org/pdf/gr-qc/9302019.pdf) that are useful if you need to go beyond basic slow roll, but there's no substitute for numerical computation if you want the full-fledged spectrum regardless of assumptions about the background expansion (you'll see that in our paper referenced above, we used the numerical computation to find power spectra for strongly non-slow roll inflation models).
Thanks for that resource! And you published a paper with Kinney, I've followed some of his notes on inflation. I have solved the dynamical equations of inflation (KG equation, Friedmann equations, etc) simultaneously in Mathematica but in the context of warm inflation, then plot out say, ##\phi##, ##\dot\phi##, ##H##, etc. So I think I'd just use the lowest order in slow roll approximation for ##P_S## and ##P_T##, I think solving it from full numerical calculation would be hard for me now (just starting in this field). But at what point in the plot of say ##\dot\phi## vs ##N## should I choose ##\dot\phi_*## to plug into ##P_S##? I think ##H## is not a problem since it looks approximately constant so I can just measure the value of ##H## anywhere in the plot and set it as ##H_*##.
We say that we countdown the number of e-foldings (N=60, 59, 58, ..., 0) from the start of slow-roll inflation and when we say that we calculate a quantity at the horizon crossing we mean say at N=60 (start of slow roll inflation, while in the plot it is N=0) so does that mean ##\dot\phi_*## is the initial condition itself?
Which N you choose depends on what length scale you wish to measure r on. The mapping between and N and k is model dependent, but for a given model, once you pick the physical length scale of interest (the scale k = 0.002 h^{-1}{\rm Mpc} was a standard one back in the day, as was k = 0.05 h^{-1}{\rm Mpc}), you can determine the corresponding N. Do you know how to map k to N?
It is N, it starts from N=0, 1, ..., 60. Should I set N= -60, -59, -58,... ,0? I don't know yet the relationship between k and N.
You can find the relationship by taking the derivative of k = aH wrt N...
Wait, ##r## is usually measured at the onset of inflation right? What's the significance of the length scale to choosing N? N should just be at least 60 e-folding right?
It's measured on CMB scales, which generally do not correspond to the onset of inflation. Remember, inflation can last arbitrarily long, for 1000s of e-folds or more. The time that we can probe with CMB and LSS is the dozen or so e-folds around N=60, corresponding to length scales from the CMB quadrupole down to around k \approx 0.1 {\rm Mpc}^{-1}. You can measure r anywhere in this observational window, but generally a standard "pivot" point is chosen. Check out the latest Planck results etc to see where people are currently constraining these observables (you need to be careful: since the scalar and tensor spectra generally have different shapes, r will vary by scale and so comparison with other's results will require that you evaluate it at the same scale!) The two pivots I quoted above were standards back when I was writing papers, 5-10 years ago.
Oh, that is why I should specify at which ##k=aH## I want to measure ##r## and that would give me the corresponding ##N##. Typical back in the days are ##aH=0.05/0.002 h^{-1} Mpc##. But why should I take the derivative of ##k=aH## with respect to ##N##? I could just plot ##k=aH## vs ##N## and find the ##k=aH## based on Planck data and get the corresponding ##N##?
As a sidenote, is ##k## defined as ##k=aH##? I thought ##k## is an independent quantity and we just set a condition ##k=aH## to specify the Hubble crossing.
Sure, that works. I only mentioned the explicit mapping so that you can see how to go from k <-> N in general. But, yes, if you have k = aH as a function of N, you just pick the k of interest, read off the N, then solve for r at that N.
That's right.
That's right.
Oh, that is very informative. Last question though, I have set my equations to be the KG equation, Friedmann equation, and the number of e-folding equation (##N=\int Hdt## or ##\frac{dN}{dt} = H##). So I don't have any equation involving the scale factor ##a## that I need to plot ##aH##. So Suppose I use the acceleration equation ##\frac{\ddot a}{a} = \frac{1}{3M_p^2} (V-\dot\phi^2)##, I would need two initial conditions ##a(0)## and ##\dot a(0)##, what do you think I should set for those two? As I remember ##a(0)## is usually set as 1? I'm not sure.
But you do have an equation for the scale factor! Can you write ##a## as a function of ##N##?
Oh, I'm sorry. I could write,
(1) ##\ddot \phi + 3H (1+Q) \dot\phi + V_{,\phi} = 0 \quad ## KG equation
(2) ##H = \frac{\dot a}{a} = \Bigg(\frac{1}{3 M_p^2} ( \frac{1}{2}\dot\phi^2 + V + \rho_r) \Bigg)^\frac{1}{2} \quad## Friedmann equation
(3) ##\frac{dN}{dt} = \frac{\dot a}{a} \quad## Number of e-folding
But due to (2) and (3) being equal, I can only explicitly use either (1) (2) or (1) (3), in my case I choose the latter so that I can also use ##N## for plotting. So how would I specify the initial conditions for ##a(0)##? Since before, I'm using ##H## instead so I just specify ##H(0) ∝ \phi(0), \dot \phi(0)##
Pick whatever you want for a(0): it's the proportionate change in ##a## that matters. Also, you've got a misplaced power of 2 in (2) (should be ##H^2##)
  • #31
Typo, I've edited it. Why do a lot of papers say that for example, we calculate ##P_S## at the horizon crossing (which is typically taken to be around 50~60 e-folds, but we can take ##N = 60##). So I have a notion that what they mean is just to get at least ##N=60## for the duration of slow roll inflation then just pick the value of the quantities at ##N=60## (start of slow-roll as we count down from 60 although the plot is counting up) and that's it, plug into ##P_S## and I got ##r##.
  • #32
##N=60## is just a rule-of-thumb. Remember, as I've been saying: the mapping between k (the scale of interest observationally) and N is model dependent. In one model, the quadrupole might map to N=60; in another, it might map to N = 55. Whichever N we pick, that's the duration of the full inflationary period, including non-slow roll. The amount of slow roll inflation also varies by model, but surely lasts for several dozens of efolds around the time that observable scales leave the horizon.
EDIT: The range of N, usually between 50 and 60, is dictated by the amount of inflation needed to solve the flatness/horizon problems. There is some leeway in the amount of inflation because the reheat temperature can generally be tweaked to compensate.
  • #33
Ok, I'll work on it first and just update this thread. Do you know of any references/books/papers that I can read that is more focused on the details of this topic? I mean, the methods on how to do things. like what we have discussed. Books usually are too general and some papers are too concise to be useful. Even just solving the simplest model (cold inflation scenario is fine) is fine as long as I get the vital points and specially how to calculate ##r##.
  • #34
I learned the basics of the inflationary perturbations calculation from Section 2.3 of Will Kinney's PhD thesis (he was my PhD advisor), available online here: http://www.acsu.buffalo.edu/~whkinney/cv/thesis/thesis.ps. He solves the power spectrum in the slow roll limit for a minimally coupled massless scalar in order to demonstrate the main ideas and important steps. (This kind of spectrum is actually the tensor spectrum; the scalar spectrum is more complicated because the field fluctuations couple to the metric, but the main ideas are the same). I'd recommend starting there if you have the appropriate background: some QFT, GR, FRW cosmology. Then, I can point you to some references that cover the full scalar spectrum calculation. Enjoy!
  • #35
I've seen in one paper that the scalar spectra amplitude ##P_S## value at the pivot scale ##k_*## is set by the CMB data at ~##10^{-9}## with ##k_* = 0.05 Mpc^{-1}##. But if that is the case, what is the point of calculating the tensor to scalar ratio ##r## if that should always be the value of ##P_S##?
  • #36
Yeah, ##r## is just another way of reporting the tensor spectrum amplitude at the scale of interest.
  • #37
I don't understand why papers got different values for ##r## for different models knowing that the observational value is already established. But that aside, I have plotted ##aH## vs. ##N##, so how do I know at which point I should get ##\dot\phi_*## and ##H_*## and solve ##P_S## at the horizon crossing?
Another thing, ##aH## is just ##\dot a## right? And ##a## is dimensionless, ##H## is measured in GeV, so my plot for ##aH## is in the units of GeV.
  • #38
1) I don't understand why this graph isn't monotonic: what's with the sharp rise as N descends from 140?
2) You read off the value of ##aH## associated with the ##N## of interest.
3) Why do you say that the observational value of ##r## is established?
  • #39
1) I also don't know how to interpret the plot of ##aH## vs ##N##, maybe you know of some resources that plots ##aH## vs ##N##? Even in the cold regime would ok.
2) In warm inflation, I could plot out the temperature and the Hubble parameter as a function of the number of e-folding, and tell from the plot what is the duration ##N## of warm inflation. So in warm inflation I know the value of ##N## for a given constraint/parameter. Should that imply that whatever ##N## I get would be the point where I calculate ##r##?
3) What I mean by that is observationaly, we know that ##P_S \approx 10^{-9}##, right?
  • #40
1) aH must be monotonically increasing as a function of N during inflation, since it is equal to 1 over the comoving horizon size (which is decreasing during inflation). I.e. there is something wrong with that plot.
2) Sounds reasonable; but the N should not necessarily be the duration of inflation, but the time when observable scales leave the horizon (around N = 60).
3) Right, but ##r## then tells you about the tensor amplitude.
  • #41
1) In this model that I have plotted, the duration ##N \approx 137##, then at ##N \approx 137## is where warm inflation ends and that is where the peak is so I think that is where aH should be equal to 1 (if I scale my y-axis properly). What do you think?
2)I'm still confused by the vagueness of the terminologies used. Can you explain more? For example, in my plot ##N## starts at 0 and changes until ~137. So ##N \approx 137##, that is the number of e-folding during inflation but of course slow roll inflation doesn't take place right away, slow roll starts around a few e-folds after ##N=0##, say ##N=5##. When do the observable scales leave the horizon? ##N=0## or ##N=5## or ##N=137##?
3) Yes, but the tensor amplitude is approximately constant, so ##r## changes value for different models/parameters only because of the scalar amplitude ##P_S## (assuming the value of ##P_S## deviates from ##10^{-9}##)
  • #42
Observable scales leave the horizon 60 e-folds before the end of inflation in cold inflation. Is that no longer the case in warm inflation? I never studied it.
Yes, the tensor spectrum is nearly constant, but it's the amplitude that ##r## gives you.
  • #43
As I know there is no consensus on this since authors sometimes write that they will take ##N=60## but they'll add that there are still debates on this since the region is still unknown. The dilemma here is that, as you can see from my op, as ##Q## changes, ##N## also changes, i.e. increasing ##Q## prolongs ##N## (as in my plots, ##N \approx 137##), so should that imply that whatever ##N## I got that would be the horizon crossing? or should I take ##N=60## as the horizon crossing? What will happen to the 77 e-folds before 60?
  • #44
I don't know what you mean by "whatever ##N## I got..". Got from where? You have a range of N, and for each N there is a mode leaving the horizon at that time. The inflation that happens before N = 60 generates fluctuations that today exist on scales well outside the cosmological horizon. That's the point of the N=60: it's the farthest back we can probe observationally, since our observations are limited by structures (really, correlations) within today's horizon.
  • #45
What I mean is that, as I solve the dynamical equations for different ##Q## and the initial conditions ##\phi(0)##, ##\dot\phi(0)## for all of the case are the same, the duration is different for each case of them. An example would be for ##Q=10^{-2}##, ##N \approx 137## as you can see from the plots in the previous post.
  • #46
The duration is not relevant to the observables as long as it's sufficient to solve the horizon/flatness problems. Whether I've got an inflation model that lasts for N=1000 or N=100, I want observables at N=60 for each.
  • #47
Then in that case, I should evaluate everything at 60 e-folds before the end of inflation. So suppose I got ##N=200##, I should evaluate the observables at ##N=140## right?
  • #48
If N = 200 is the end, then yes. FYI, conventionally the variable ##N## is defined as the number of e-folds before the end of inflation (which is why I've been saying N=60 this whole time).
  • #49
Yeah, what you mean by ##N=60## is where we start counting towards the end of inflation. If that is the case, I can just find the quantity in the plot at ##N=60## before the end of inflation, so what's the point of plotting ##k=aH## right? So I can just get ##\dot\phi_*##, and ##H_*## at ##N=60## before the end of inflation in the plot.
  • #50
Well, you originally asked for the spectrum as a function of ##k##, remember?
