Calculating the thrust required to turn a submarine deep in the water
Designing an AUV with a bow thruster requires careful consideration of power needs for turning at a steady angular velocity. Key factors include the AUV's weight, size, power consumption, and desired turn time, as well as the effects of water currents. Calculating the drag while turning is essential, with suggestions to estimate power requirements based on holding the vessel stationary against current. The discussion emphasizes the importance of defining the current conditions the AUV will face, as this will influence design decisions. Overall, mathematical approaches are preferred over experimental methods for determining thrust requirements.
Riyadh
Dear All,
I am designing a AUV and trying putting a bow thruster in the front. I am kinda confused that how much power do I need to turn my AUV by a steady angular velocity. Could anyone pls help me with this.
Regards
Working blind here.
Power could be any value. I am guessing it should be about 0.1 HP.
Firstly, briefly describe your AUV - weight, size, power consumption, duration of underwater expedition, desired time to make a turn, etc. That might cog someone with experience with a similar problem or knowledge of underwater vehicles to offer aid.
You must at least have some idea of what your desired goal is.
And how much knowledge you have on this subject would not hurt either.
Likes 1 person
I am looking for the formulas or the procedure to calculate the drag while turning for any typical AUV of any size.
I would guess that drag is small compared to the forces caused by currents impinging at angles such as 45 degrees.
Here is a way to guess. Calculate, or fiind by experiment, how much primary propulsion power is needed to hold the vessel stationary against X knots of current bow-on. The power needed by the thruster and rudder to hold constant angle against X knots at 45 degrees is comparable within a factor of two.
Your biggest job is to decide how much X to design for. Unless you are in a swimming pool, X is seldom zero.
Good luck
Ah, Cant do experiments. Anything mathematically
Can you make the primary propulsion in pods that rotate 360 degrees? Modern ships do that. One pod fore, one aft and you have it. No separate thruster needed.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
