Calculating time of object given its speed
  • Thread starter Thread starter Erenjaeger
    Speed Time
To calculate the time it takes for a nerve impulse to travel 1.77 m at a speed of 121 m/s, the formula t = d/s is used. The initial confusion arose from incorrect rounding of the answer to two decimal places instead of three. It was clarified that the correct calculation yields a time of approximately 0.015 m/s. Additionally, it was noted that reflex actions occur via spinal cord circuits, meaning the brain does not need to process the impulse for immediate reactions. Understanding these concepts is crucial for solving similar physics problems.
Erenjaeger
You step onto a hot beach with your bare feet. A nerve impulse, generated in your foot, travels through your nervous system at an average speed of 121 m/s. How much time does it take for the impulse, which travels a distance of 1.77 m, to reach your brain?
seems like an easy question but have never learned how to do this.
thought it could be t=d/s but it gave me the wrong answer
please post your answer, and the official answer if you know it.
My mistake, i was doing it correctly but rounding to 2 dp when they wanted 3dp.
Ok!
For what it's worth, nerve impulses from the limbs do not need to reach the brain before you react. Circuits in the spinal cord act first.
Likes Erenjaeger
