Calculating Travel Time Difference in Optical Fiber | Refraction Homework"
  • Thread starter Thread starter lvjudge
    Diffraction
The problem involves calculating the difference in travel times for light traveling through an optical fiber with two distinct paths: one directly along the central axis and the other reflecting at the critical angle along the core-sheath interface. The context is rooted in the principles of refraction and the behavior of light in materials with different indices of refraction.
  • Participants discuss the initial calculations of travel times based on different speeds of light in the core and sheath. Questions arise regarding the nature of the two paths and the implications of the critical angle. There is a focus on determining the correct path length for the reflected light.
The discussion is ongoing, with some participants recognizing the need to clarify the differences between the two paths. Guidance has been offered regarding the geometric nature of the problem, suggesting a focus on the path length rather than interference equations.
Participants are working under the constraints of the problem statement and are exploring the implications of the critical angle and the geometry of the optical fiber. There is an acknowledgment of the initial misunderstanding regarding the paths taken by the light.
lvjudge
The figure below shows an optical fiber in which a central plastic core of index of refraction n1 = 1.58 is surrounded by a plastic sheath of index of refraction n2 = 1.51. Light can travel along different paths within the central core, leading to different travel times through the fiber. This causes an initially short pulse of light to spread as it travels along the fiber, resulting in information loss. Consider light that travels directly along the central axis of the fiber and light that is repeatedly reflected at the critical angle along the core-sheath interface, reflecting from side to side as it travels down the central core. If the fiber length is 275 m, what is the difference in the travel times along these two routes?
v=c/n
This is my initial failed attempt at a solution
v1=c/n1=189742062
v2=c/n2=198538051.7
The time it takes light traveling at v1 to go 275m:
t1=275/v1=1.449335994E-6 s
The time it takes light traveling at v2 to go 275m:
t2=275/v2=1.385124905E-6 s
delta t=t1-t2=6.421109383E-8=64.21109383 ns
However, this answer was marked incorrect, so i would like so help figuring out how to solve the problem correctly
Both paths are in the central fiber of n1=1.58, and thus have the same speed.
Read the question again. Just what is different about the 2 paths?
Ok, now I see. The first path is just straight through the center. but the second path is reflected off the side of the wire at the critical angle.
I found the critical angle using theta=arcsin(n2/n1)=1.272015952 rad
Now that I've got this information, I really can't figure out where to go or which equation to use. It looks like the variable I need to find is path length for the second path. There's an equation in my textbook from Young's Interference Experiment that states delta L=d sin theta. Is this the one that I should be using?
No, this isn't really an interference or diffraction problem.
It's more of a geometry problem. In the figure you gave, find the ratio of the red path to the dashed-line path.
16K
