Calculating Vertical Jump on Earth and the Moon
The discussion revolves around calculating the vertical jump of a person on the Moon based on their jump height on Earth. The problem involves gravitational forces and the masses of the Earth and Moon.
  • Participants explore the relationship between gravitational forces on Earth and the Moon, questioning the relevance of Earth's gravitational constant and the necessary mass values for calculations. Some suggest using conservation of energy to approach the problem.
Participants have provided insights into the gravitational constants and mass values, with some suggesting methods to relate the forces experienced on both celestial bodies. There is an ongoing exploration of how these factors influence jump height, but no consensus has been reached.
Participants note the lack of specific values in the textbook and question whether the gravitational constant is applicable in both scenarios. They also discuss the need for additional information regarding the masses and radii of the Earth and Moon.
alison16
On Earth, an average person's vertical jump is 0.40m. What is it on the Moon?
Fg 1 on 2 = G(m1m2/r^2)
G= 6.67 x 10^-11
r= 0.40m
F Earth on person on Earth's surface = 6.67x10^-11(m Earth x m person)/(0.40)^2
r=?
G moon = ?
F moon on person on Moon's surface = G(m moon x m person)/r^2[/B]
I'm pretty stuck, and I don't understand if Earth is helpful in solving it or not. The textbook does not give any relevant values/equations except for the ones I typed under 1 and 2. Is G of the moon also 6.67 x 10^-11?
Hi Alison16, Welcome to Physics Forums.
G is the same for Earth and the Moon and anywhere else; it's what's called a Universal Constant and applies everywhere.
What information do you have about the masses or relative masses of the Earth and Moon? Or perhaps you were given some information about the relative strength of gravity on the Moon versus Earth? You might have to look these things up in your text or course notes.
Thanks! I think I found more information. In an example problem, it uses 6.0 x 10^24 kg as Earth's mass. And Moon's as 7.35 x 10^22 kg. Will I use Earth's mass to find the m person? And then use that information to solve F moon on person on Moon's surface = G(m moon x m person)/r^2?
I think a better approach would be to find the acceleration due to gravity on the Moon's surface (you should already know what it is at the Earth's surface), and then think about conservation of energy. When a person makes a jump, they give themselves some initial kinetic energy depending upon their strength. Assume that it's the same amount of energy they can manage in both cases.
The difference will depend upon two things- the difference in masses of the Earth and moon and the difference in radii of the eath and moon.
For a person of mass m on the Earth [itex]F_e= \frac{GmM_e}{r_e^2}[/itex] where [itex]M_e[/itex] the mass of the Earth and [itex]r_e[/itex] is its radius. Similarly for a person of mass m on the Earth [itex]F_m= \frac{GmM_m}{r_m^2}[/itex] where [itex]M_m[/itex] the mass of the moon and [itex]r_m[/itex] is its radius.
The ratio of force on the moon to force on the Earth is one divided by the other [itex]\frac{GmM_m}{r_m^2}\frac{r_e^2}{GmM_e}[/itex]. The "Gm" terms cancel leaving [itex]\frac{M_m r_e^2}{M_er_m^2}= \frac{M_m}{M_e}\left(\frac{r_e}{r_m}\right)^2[/itex].
Now, how is the height an object can rise to determined by the gravitational force on it?
I understand now! Thank you all very much! :)
  • · Replies 73 ·
  • · Replies 23 ·
