Calculating Work Done by a Battery in a Circuit with a Resistor and Capacitor
  • Context: Undergrad
  • Thread starter Thread starter willydavidjr
    Battery Work Work done
The discussion revolves around calculating the work done by a battery in a circuit containing a resistor and a capacitor. Participants explore various approaches to understanding the energy dynamics in such a circuit, including theoretical derivations and practical implications.
  • One participant seeks guidance on computing the work done by the battery in a circuit with a resistor and capacitor.
  • Another participant references a derivation of the work done by the battery, suggesting that the energy stored in the capacitor can be expressed as U = Q²/2C.
  • Some participants discuss the relationship between power and work, with one suggesting that the power dissipated by the resistor can be used to determine the work done.
  • It is noted that the energy dissipated during the charging of a capacitor equals the energy stored in the capacitor, leading to the equation U = Q²/C.
  • One participant argues that the energy delivered by the battery is twice that of the energy stored in the capacitor, with the other half dissipated as heat in the resistor.
  • A participant proposes a method to calculate the energy stored in the capacitor by analyzing the energy dissipated in the resistor after the battery is removed.
  • There is a discussion about the relationship between the energy in the capacitor and the energy provided by the battery, with one participant confirming that if the energy in the capacitor is 20 joules, the energy in the battery would be 40 joules.
Participants express differing views on the relationship between the energy stored in the capacitor and the work done by the battery. While some agree on the equations presented, there is no consensus on the interpretation of energy dynamics in the circuit.
Some participants highlight that prior to reaching a steady state, more energy is dissipated as heat than is stored in the capacitor. The discussion includes various assumptions about the initial conditions of the capacitor and the battery's voltage.
This discussion may be useful for students and enthusiasts interested in electrical circuits, energy storage in capacitors, and the principles of work and power in electrical systems.
willydavidjr
Can someone give me an idea how to compute or how to get the work done by the battery if there is a circuit given with resistor and a capacitor?
Power relates to work, right? ...
What are you getting at?
~H
Presumably he can figure out the power dissipated by the resistor, and get the amount of work done through that component of the system.
Yeah, he could. But it also takes work to place charge on the capacitor plates.
~H
Right. But you already covered that part, and I didn't have anything to add to it.
Oh right, I thought I was missing something, like you could just work out the problem by considering power dissapated by the resistors. Thanks
~H
~H
Matter of fact you could!
The energy dissipated during the charging of a capacitor equals the energy stored in the capacitor at the end of the process.
So the total energy that battery gave away is
[tex]U = \frac{Q^2}{C}[/tex]
It's more complicated to consider it from the resistor side than from the capacitor side I suppose.
It's clear that when the battery is disconnected, the power subsequently dissipated by the resistor will be exactly the energy stored in the capacitor.
But I don't see why there should be such a trivial relationship between the power dissipated by the resistor with the power stored in the capacitor during the time the capacitor is charging!
It's a just a variant of Kelvin's rule applied to electrical circuits.
If you don't trust me, write down differential equation ,solve it in current :wink: , and take the integral of [tex]i^2 R dt[/tex].
Ratio of two energies will be always the same regardless of electromotive force of the source [tex]E[/tex],resistance [tex]R[/tex] of the circuit, and amount of capacitance [tex]C[/tex] in the circuit!:smile:
I would reason like this:
Assuming the battery voltage is constant:
[tex]\text{Work by the battery} = \int V_{battery} I dt = V_{battery} Q[/tex]​
and since at the end of the charging
[tex]Q = C V = C V_{battery}[/tex]​
we get
[tex]\text{Work by the battery} = C V_{battery}^2[/tex]​
(I assumed the capacitor has no charge at the beginning)
Meaning the energy that occurs in the capacitor is also the same as the energy use by the battery?
And it goes like this?
[tex]E=\frac{1}{2}qV = \frac{1}(2}CV^2 = \frac{q^2}{2C}[/tex]
Am I right?
I don't CARE what work the battery is doing, the battery needs to get its smelly arse back to Mexico! :-p
No!You are missing the point.
The energy that is delivered by the battery is twice as high as the energy of the capacitor.
Other half is dissipated by the resistor during the charging as the heat.
You have a simple energy bilance :
[tex]W_{battery}=\int_{0}^Q Vdq=QV=W_{dissipated}+U_{capacitor}=W_{dissipated}+ \frac{VQ}{2}[/tex]
Maybe I should emphasize that prior to the stationary state established,more energy is spent as a Joule heat than being stored in the capacitor. Also easy to show that.
Hi,
I think something is still missing in this thread: what is the energy stored in the capacitor, and how this can be proved/calculated.
My suggestion on how to do that:
once the capacitor is charged, calculate how much energy it will dissipate in the resistor if the battery is removed and replaced by a shortcut. The calculation is similar to the previous work done by the battery except that the voltage on the capacity will decrease during this process. The outcome is then the 1/2 factor.​
But I think there is a better way to proof the formula for the capacitor energy storage. I don't remember, help me.
Michel
PS:
The fact that the work done goes in equal amounts to dissipation and to storage in the capacity is strinking. Is it related to a more general rule?
energy=1/2q^2/c= 1/2C^2V... Can I ask, do you know what is the formula for the work done by the battery? Thanks.
Techno you mean, if the energy in capacitor is 20 joules, the energy in the battery is 40 joules? Am I right?
That's right.
  • · Replies 24 ·
  • · Replies 77 ·
  • · Replies 23 ·
