Calculating Work Done by a Variable Force
  • Thread starter Thread starter ecthelion4
    Variables Work
The discussion focuses on calculating the work done by a variable force defined as F = bx^3, where b is 3.7 N/m^3. The correct approach involves using integration to account for the variable nature of the force over the distance from x = 0.0 m to x = 2.2 m. The final calculation yields a work done of 22 Joules after evaluating the definite integral of the force function. This method is essential for accurately determining work when dealing with variable forces.
  • Understanding of variable forces and their mathematical representation
  • Knowledge of integration techniques in calculus
  • Familiarity with the concept of work in physics
  • Ability to evaluate definite integrals
  • Study the principles of variable forces in classical mechanics
  • Learn how to perform definite integrals with variable limits
  • Explore the application of work-energy theorem in physics
  • Review calculus techniques for integrating polynomial functions
Students in physics or engineering, educators teaching mechanics, and anyone interested in understanding the calculation of work done by variable forces.
ecthelion4
A force F=bx^3 acts in the x-direction. How much work is done by this force in moving an object from x=0.0m to x=2.2m? The value of bis 3.7 N/m^3
Work=Force*Distance
Ok since the above equation is true, then the problem would solution would be obtained by simply multiplying our force which is (3.7N/m^3) by the given distance which would be 2.2m. The thing is that once you do that, the problem is over and there is still a variable there bothering us which is x^3. What am I supposed to do with that variable?
(3.7N/m^3)
This is not the force, this is a constant. The force is b*x^3. Since it contains the x^3 term, the force is variable and you can't use W=Fd. Do you know integration?
yes, but how would i use it in this case?edit: ok i figured it out, it should be the definite integral from 0-2m of F right?
Yes, but the upper limit is 2.2m, right? :smile:
that was exactly it. The answer was 21.6 which rounded up to 22J . Thanks you were a great help!
  • · Replies 19 ·
