Calculation of Oscillation Period- Short Problem
The problem involves calculating the oscillation period of a solid thin rod acting as a physical pendulum. The correct formula to use is T = 2π * √(I/mgh), where I is the moment of inertia, m is mass, g is gravitational acceleration, and h is the height of the pivot. The initial attempt using T = 2π * √(L/g) was incorrect because it does not account for the rod's moment of inertia. Additionally, to find the initial angle from vertical, the height variation of 2 cm must be considered in relation to the pendulum's motion. Understanding the distinction between a simple pendulum and a physical pendulum is crucial for solving this problem accurately.
BDM333
You drill a hole at the end of a solid thin rod of length 1.3 m, and then attach the rod through this hole onto an approximately frictionless pivot. You then release the rod from rest at a reasonably small angle from vertical, so that it executes simple harmonic motion.
L=1.3m
a.) What will be its oscillation period? _____ seconds
b.) If the bottom of the rod varies its height above the ground by 2 cm during the oscillation, what was its initial angle from the vertical? ______ degrees
(Note: You may assume the width of the stick is negligible to make this well defined.)
T = 2pi * sq root (L/g)
I = (1/3) M L^2 ... should I incorporate this equation for a thin rod?
For part A, tried the T = 2pi * sq root (L/g) equation but got 2.2884 which was wrong
I didn't do part b, b/c I think I am missing some key concept for this problem
