Calculation of real integration
In summary: ∫ 2*cos^2(arctan(u)) du/[13 - 5*2*sin(arctan(u))*cos(arctan(u))] adjacent = 1; opposite = u; hypotenuse = sqrt((u^2) + 1) ∫ 2*[(1/sqrt((u^2) + 1))^2] du / [13 - 10*(u/sqrt((u^2) + 1))*1/sqrt((u^2) + 1)] ∫ [2/((u^2) + 1)] du / [13 - (10u/((u^2) + 1))] ∫ 2 du
aruwin
208
Hi.
Is there a short way to calculate real integration? I tried it but it looks so tedious. I attached the question so please refer to that. I am stuck with no.1, by the way.
Here is my attempt:
∫_0^(2π) dx/(13 - 5*sin(x))
let u = tan(x/2) which means x/2 = arctan(u) which means x = 2*arctan(u);
let du = sec^2(x/2)/2 dx
∫ 2*sec^2(x/2) dx/[2*sec^2(x/2)*(13 - 5*sin(x))]
∫ 2 du/[sec^2(2*arctan(u)/2)*(13 - 5*sin(2*arctan(u)))]
∫ 2*cos^2(arctan(u)) du/[13 - 5*sin(2*arctan(u))]
∫ 2 du / {[13 - (10u/((u^2) + 1))]*[(u^2) + 1]}
∫ 2 du / {13*[(u^2) + (1)] - (10u)}
∫ 2 du / [13*(u^2) + (13) - (10u)]
∫ 2 du / [13*(u^2) - (10u) + (13)]
∫ (2/13) du / [(u^2) - (10/13*u) + (1)]
p = (u^2) - (10/13*u) + 1
p + (25/169) = (u^2) - 10/13*u + 1 + (25/169)
p + (25/169) = ((u - 5/13)^2) + 1
p = ((u - 5/13)^2) + (144/169)
∫ (2/13) du / {[(u - (5/13))^2] + [(12/13)^2]}
b = u - 5/13; db = du
∫ (2/13) db / [(b^2) + ((12/13)^2)]
a = 12/13; b = 12/13*tan(t); db = 12/13*sec^2(t) dt
∫ (2/13) [12/13*sec^2(t) dt] / [((12/13)^2)*tan^2(t) + ((12/13)^2)]
∫ ((13/12)^2) * (2/13) * (12/13) * sec^2(t) dt /[tan^2(t) + 1]
∫ ((13/12)^2) * (2/13) * (12/13) dt = ∫ dt/6 = t/6
b = 12/13*tan(t) as t = arctan(13b/12)
arctan(13b/12)/6 as b = u - 5/13
arctan[13*(u - 5/13)/12]/6 = 1/6*arctan((13u - 5)/12) as u = tan(x/2) as x = 2*arctan(u)
NOT SURE WHAT THE FINAL ANSWER IS.
2) ∫_-∞^∞ dx/((x^2) + 4)^2
a = 2; x = 2*tan(t); dx = 2*sec^2(t) dt;
∫ 2*sec^2(t) dt/(4*tan^2(t) + 4)^2
1/8 * ∫ sec^2(t) dt/(sec^4(t))
1/8 * ∫ cos^2(t) dt
1/8 * ∫ (1 - sin^2(t)) dt
u = sin(t); du = cos(t) dt; dv = -sin(t); v = cos(t)
t + sin(t)*cos(t) - ∫cos^2(t) = ∫cos^2(t)
t + sin(t)*cos(t) = 2*∫cos^2(t)
[t + sin(t)*cos(t)]/16
x/2 = tan(t) as t = arctan(x/2)
[arctan(x/2) + sin(arctan(x/2))*cos(arctan(x/2))]/16
adjacent = x; opposite = 2; hypotenuse = sqrt((x^2) + 4)
[arctan(x/2) + (2/sqrt((x^2) + 4))*(x/sqrt((x^2) + 4))]/16
[arctan(x/2) + (2x/((x^2) + 4))]/16
limit x->∞ [arctan(x/2) + (2x/((x^2) + 4))]/16
limit x->∞ [(π/2) + 2/(2x)]/16 = π/32
limit x->-∞ [arctan(x/2) + (2x/((x^2) + 4))]/16
limit x->-∞ [(π/2) + 2/(2x)]/16 = -π/32
Final answer is π/16
1/8 * ∫ cos^2(t) dt
I agree with you up to here, now $\displaystyle \begin{align*} \cos^2{(t)} \equiv \frac{1}{2} + \frac{1}{2}\cos{(2t)} \end{align*}$ so
$\displaystyle \begin{align*} \int{ \cos^2{(t)}\,\mathrm{d}t} &= \int{ \frac{1}{2} + \frac{1}{2}\cos{(2t)}\,\mathrm{d}t} \\ &= \frac{1}{2}t + \frac{1}{4}\sin{(2t)} + C \\ &= \frac{1}{2}t + \frac{1}{2}\sin{(t)}\cos{(t)} \\ &= \frac{1}{2}t + \frac{1}{2}\tan{(t)}\cos^2{(t)} + C \\ &= \frac{1}{2}t + \frac{\tan{(t)}}{2\sec^2{(t)}} + C \\ &= \frac{1}{2}t + \frac{\tan{(t)}}{2 \left[ 1 + \tan^2{(t)} \right] } + C \\ &= \frac{1}{2}\arctan{ \left( \frac{x}{2} \right) } + \frac{\frac{x}{2}}{2 \left[ 1 + \left( \frac{x}{2} \right) ^2 \right] } + C \\ &= \frac{1}{2}\arctan{ \left( \frac{x}{2} \right) } + \frac{\frac{x}{2}}{ 2 \left( 1 + \frac{x^2}{4} \right) } +C \\ &= \frac{1}{2}\arctan{ \left( \frac{x}{2} \right) } + \frac{x}{4 + x^2} + C \end{align*}$
Anyway, since the integrand is an even function, that means
$\displaystyle \begin{align*} \int_{-\infty}^{\infty}{ \frac{\mathrm{d}x}{ \left( x^2 + 4 \right) ^2 } } &= 2\int_0^{\infty}{ \frac{\mathrm{d}x}{ \left( x^2 + 4 \right) ^2 } } \\ &= 2 \lim_{\epsilon \to \infty}{ \left[ \frac{1}{2}\arctan{ \left( \frac{x}{2} \right) } + \frac{x}{4 + x^2} \right] _0^{\epsilon} } \\ &= \frac{\pi}{2} \end{align*}$
What about no. 1? What is the final answer?
You're welcome >_<
Prove It said:
You're welcome >_<
Opps, sorry sorry! Thank you! I was so desperate about the answer that I forgot my manners. Forgive me.
aruwin said:
Hi.
Here is my attempt:
1/8 * ∫ cos^2(t) dt
If you're going to make the substitution $\displaystyle \begin{align*} u = \tan{ \left( \frac{x}{2} \right) } \implies \mathrm{d}u = \frac{1}{2}\sec^2{ \left( \frac{x}{2} \right) } \end{align*}$ then
$\displaystyle \begin{align*} \sin{(x)} &= 2\sin{ \left( \frac{x}{2} \right) } \cos{ \left( \frac{x}{2} \right) } \\ &= 2 \tan{ \left( \frac{x}{2} \right) } \cos^2{ \left( \frac{x}{2} \right) } \\ &= \frac{2\tan{ \left( \frac{x}{2} \right) } }{\sec^2{ \left( \frac{x}{2} \right) } } \\ &= \frac{2\tan{ \left( \frac{x}{2} \right) } }{ 1 + \tan^2{ \left( \frac{x}{2}\right) } } \\ &= \frac{2u}{1 + u^2} \end{align*}$
and so the integral is
$\displaystyle \begin{align*} \int{ \frac{\mathrm{d}x}{13 - 5\sin{(x)}}} &= \int{ \frac{ \frac{1}{2}\sec^2{ \left( \frac{x}{2} \right) }\,\mathrm{d}x}{ \frac{1}{2}\sec^2{ \left( \frac{x}{2} \right) } \left[ 13 - 5\sin{(x)} \right] } } \\ &= \int{ \frac{\mathrm{d}u}{\frac{1}{2} \left[ 1 + \tan^2{ \left( \frac{x}{2} \right) } \right] \left\{ 13 - 5 \left[ \frac{2u}{1 + u^2} \right] \right\} } } \\ &= 2\int{ \frac{\mathrm{d}u}{\left( 1 + u^2 \right) \left( 13 - \frac{10u}{1 + u^2} \right) } } \\ &= 2\int{ \frac{\mathrm{d}u}{ 13u^2 - 10u + 13} } \\ &= \frac{2}{13} \int{ \frac{\mathrm{d}u}{u^2 - \frac{10}{13}u + 1 } } \\ &= \frac{2}{13} \int{ \frac{\mathrm{d}u}{ u^2 - \frac{10}{13}u + \left( -\frac{5}{13} \right) ^2 - \left( -\frac{5}{13} \right) ^2 + 1 } } \\ &= \frac{2}{13} \int{ \frac{\mathrm{d}u}{ \left( u - \frac{5}{13} \right) ^2 - \frac{25}{169} + \frac{169}{169}} } \\ &= \frac{2}{13} \int{ \frac{\mathrm{d}u}{ \left( u - \frac{5}{13} \right) ^2 + \frac{144}{169} } } \\ &= \frac{2}{13} \int{ \frac{\mathrm{d}u}{ \left( u - \frac{5}{13} \right) ^2 + \left( \frac{12}{13} \right) ^2 }} \end{align*}$
Now make the substitution $\displaystyle \begin{align*} u - \frac{5}{13} = \frac{12}{13}\tan{ \left( \theta \right) } \implies \mathrm{d}u = \frac{12}{13} \sec^2{ \left( \theta \right) }\,\mathrm{d}\theta \end{align*}$ and the integral becomes
$\displaystyle \begin{align*} \frac{2}{13} \int{ \frac{\mathrm{d}u}{ \left( u -\frac{5}{13} \right) ^2 + \left( \frac{12}{13} \right) ^2 } } &= \frac{2}{13} \int{ \frac{ \frac{12}{13}\sec^2{ \left( \theta \right) } \,\mathrm{d}\theta }{ \left[ \frac{12}{13} \tan{\left( \theta \right) } \right] ^2 + \left( \frac{12}{13} \right) ^2 } } \\ &= \frac{2}{13} \int{ \frac{ \frac{12}{13} \sec^2{ \left( \theta \right) } \,\mathrm{d}\theta }{ \left( \frac{12}{13} \right) ^2 \sec^2{ \left( \theta \right) } } } \\ &= \frac{1}{6} \int{ \mathrm{d}\theta } \\ &= \frac{1}{6}\theta + C \\ &= \frac{1}{6} \arctan{ \left( \frac{13u - 5}{12} \right) } + C \\ &= \frac{1}{6} \arctan{ \left[ \frac{13 \tan{ \left( \frac{x}{2} \right) } - 5 }{12} \right] } + C \end{align*}$
Thus
$\displaystyle \begin{align*} \int_0^{2\pi}{ \frac{\mathrm{d}x}{ 13 - 5\sin{(x)} } } &= \frac{1}{6} \left\{ \arctan{ \left[ \frac{13\tan{\left( \frac{x}{2} \right) } - 5}{12} \right] } \right\}_0^{2\pi} \\ &= \frac{1}{6} \left\{ \arctan{ \left[ \frac{13\tan{ \left( \pi \right) } - 5}{12} \right] } - \arctan{ \left[ \frac{13\tan{ (0) } - 5}{12} \right] } \right\} \\ &= \frac{1}{6} \left[ \arctan{ \left( -\frac{5}{12} \right) } - \arctan{ \left( -\frac{5}{12} \right) } \right] \\ &= 0 \end{align*}$
It may be that some objection is to move to the 'solution' $\displaystyle \int_{0}^{2\ \pi} \frac{d \theta}{13 - 5\ \sin \theta} =0$. It is easy to see that in $[0,2\ \pi]$ is $\displaystyle \frac{1}{13 - 5\ \sin \theta} > 0$...
Kind regards
$\chi$ $\sigma$
The procedure for solving the definite integral...
$\displaystyle I=\int_{0}^{2\ \pi} \frac{d \theta}{13 - 5\ \sin \theta}\ (1)$
... through the substition $\displaystyle u=\tan \frac{\theta}{2}$ is correct. Taking into account that for $\theta$ going from 0 to $2\ \pi$ u goes from $- \infty$ to $+ \infty$ we arrive at the integral...
$\displaystyle I = 2\ \int_{- \infty}^{+ \infty} \frac{d u}{13 - 10\ u + 13\ u^{2}} = \frac{1}{6}\ \lim_{l \rightarrow \infty} |\tan^{-1} \frac{13\ u - 5}{12}|_{- l}^{+ l} = \frac{\pi}{6}\ (2)$
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
But surely $\displaystyle \begin{align*} \tan{ \left( \frac{0}{2} \right) } = 0 \end{align*}$, not $\displaystyle \begin{align*} \to \infty \end{align*}$
Kind regards
$\chi$ $\sigma$
The result can be obtained in faster way using the general formula reported in...
http://mathhelpboards.com/calculus-10/integration-help-11145.html#post51926
... that I suggest memorizing ...
$\displaystyle \int \frac{dx}{a + b\ x + c\ x^{2}} = \frac{2}{\sqrt{\Delta}}\ \tan^{-1} \frac{b + 2\ c\ x}{\sqrt{\Delta}},\ \Delta = 4\ a\ c - b^{2}\ (1) $
Kind regards
$\chi$ $\sigma$
As $\theta$ goes from $0$ to $2\pi$, $u = \tan\frac\theta2$ goes from $0$ to $\infty$ (in the first half of the interval) and then from $-\infty$ to $0$ (in the second half of the interval). So as $\theta$ goes through the entire interval, $u$ covers the whole real line from $-\infty$ to $\infty$.
What about Residue Theorem? I think we can use that for this integration.
Which function and contour would you choose?
Yes, you can use that method. You need to make the substitution $z = e^{ix} = \cos x + i \sin x$. Then $dz = ie^{ix}dx = iz\,dz$ so that $dx = \frac {dz}{iz}.$ Also, $z^{-1} = \cos x - i \sin x$, so that $\sin x = \frac1{2i}{z-z^{-1}}.$ The integral then goes round the unit circle $C$ and is equal to $$\begin{aligned} \oint_C \frac1{13-\frac5{2i}(z-z^{-1})}\,\frac{dz}{iz}\ &= \oint_C \frac{2\,dz}{26iz - 5z(z-z^{-1})} \\ &= \oint_C \frac{-2\,dz}{5z^2 - 26iz - 5} \\ &= \oint_C \frac{-2\,dz}{(5z-i)(z-5i)}.\end{aligned}$$ By the residue theorem, that last integral is equal to $2\pi i$ times the residue at the only pole inside the contour, which is at $z = i/5.$ The residue there is $\dfrac{-2i}{24}$ and that gives the value of the integral as $\dfrac{\pi}6$ (in agreement with chisigma's result at comment #8 above).
You can also do the other integral \(\displaystyle \int_{-\infty}^{\infty} \frac{dx}{(x^2+4)^2}\) by contour integration. This time, integrate $\dfrac1{(z^2+4)^2}$ around a contour consisting of the interval $[-R,R]$ of the $x$-axis followed by a semicircle of radius $R$ in the upper half-plane, and then let $R\to\infty$.
Related to Calculation of real integration
1. What is real integration?
Real integration is a mathematical process used to find the area under a curve in a given interval. It involves splitting the area into smaller and smaller rectangles and calculating their individual areas, then summing them up to get an approximation of the total area.
2. What is the difference between real integration and numerical integration?
Real integration involves finding an exact solution to the area under a curve, while numerical integration uses various approximation methods to estimate the area. Real integration provides a more accurate result, but can be more time-consuming and difficult to calculate.
3. What are the different methods of calculating real integration?
The most commonly used methods for calculating real integration are the Riemann sum, the Trapezoidal rule, and Simpson's rule. These methods involve dividing the area under the curve into smaller sections and using mathematical formulas to approximate their areas and sum them up.
4. What is the purpose of calculating real integration?
The main purpose of calculating real integration is to find the area under a curve, which has many real-world applications such as calculating volumes, finding average values of functions, and determining probabilities in statistics and physics.
5. What are some common challenges when calculating real integration?
Some common challenges when calculating real integration include choosing the appropriate method to use, dealing with complex functions or intervals, and ensuring accuracy in the calculations. It can also be challenging to interpret the results and understand their significance in real-world scenarios.
  • Topology and Analysis
  • Calculus
