Stuck with Maths? Help Needed with Casio fx-85MS Calculator
The user is seeking help with using the Casio fx-85MS calculator for a financial calculation involving a discount factor. They specifically need assistance with the power function to compute 2000/(1+0.08) to the power of 9. A response indicates that the correct button for powers is labeled with a caret (^) and is located above the sine function. Additionally, the EXP function can be used for powers of 10, providing an example for clarification. The discussion emphasizes the need for clear guidance on using the calculator effectively.
barry@white23.wanado
Hi all. I have a Casio fx-85MS scientific calculator but forgot how to work it. I need to do calculations like 2000/(1+0.08) to the power of 9. Its a formula for working out the value of money in x amount of years at 8% discount factor. I can't rememer how to get the power of function on the calculator to work, I thought it was EXP something but can't figure it out. I even downloaded the userguide but can't understand it. Incase you havn't guessed its been a while since I needed to do mahts,
Any ideas?
Thanks
Mathematics news on Phys.org
The button labeled ^ should be the right one. According to a picture of this calculator I've found it is just above sin.
Use EXP to get powers of 10. For example: EXP,5,EXE would be the same as 10,^,5,EXE. Both results will be 100000.
Regards,
nazzard
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
15K
24K
