Calculus 1: Finding the maxima and minima of the function 1-x^(2/3)
The function defined by f(x) = 1 - x^(2/3) has critical points that require analysis to determine maxima and minima. The derivative, y' = -(2/3)x^(-1/3), is undefined at x = 0, indicating a potential extremum. However, since the derivative does not exist at this point, it is classified as an "interesting point" rather than a maximum or minimum. The function does not exhibit any absolute or relative maxima or minima across its domain.
  • Understanding of calculus concepts, specifically derivatives and critical points.
  • Familiarity with the behavior of functions and their graphs.
  • Knowledge of how to classify extrema (maximum and minimum points).
  • Ability to interpret undefined derivatives in the context of function analysis.
  • Study the classification of critical points in calculus.
  • Learn about the implications of undefined derivatives in function analysis.
  • Explore graphing techniques for functions with fractional exponents.
  • Investigate the concept of limits and continuity at critical points.
Students studying calculus, particularly those focusing on finding extrema of functions, as well as educators looking for examples of critical point analysis.
dez_cole
I am given the problem "A function is defined by f(x) = 1-x^(2/3).
a. find the minima and maxima of the function. State whether they are relative or absolute.
b. graph the function."
I found the derivative and set it equal to zero. y' = -(2/3)x^(-1/3), -(2/3)x^(-1/3) = 0
Now I really have little idea of where to go from here because I am left with a few questions. If i set the derivative equal to zero and set x to be zero would the statement "-(2/3)0^(-1/3) = 0" be true or would I essentially be dividing by zero because x^(-1/3) = 1/ [itex]\sqrt[3]{x}[/itex]? Now if this is a spot where the velocity is zero would you consider it a max, a min, or would it be irrelevant to my answer because you can't quite classify it either way. I think it is simply an interesting value on the graph, but is neither a maximum or minimum relative or absolute, and this graph has no maxes or mins.
Thanks for your help. I really appreciate it.
Sketch a graph. You are correct that the derivative at x=0 doesn't exist. It still might be a max or a min. It's an "interesting point" as you put it.
Thanks again.
