Calculus 3 vector analysis question (Newton's 2nd problem)
chongj12
This problem was discussed in my calculus 3 class, and there is one step that I don't understand.
An object of mass m travels along the parabola y = x^{2} with a constant speed of 10 units/sec. What is the force on the object due to its acceleration at (0,0) (write the answer in terms of unit vectors i,j,k)? (this problem is from Thomas' calculus 11th edition, section 13.5 #20)
f(x) = x^{2}
a = atT + anN
at = d(|v|)/dt
an = kappa|v|^{2}
T = v/|v|
kappa = |f''(x)|/((1+f'(x)^{2})^{3/2})
r = ti + t^{2}j
=> v = i+2tj
=> |v| = (1+4t^{2})^{1/2}
N = (d(T)/dt)/(|d(T)/dt|)3. The Attempt at a Solution **** this was the solution presented in class:
at = 0 because d(10)/dt = 0
an = 100kappa
kappa = 2 at the point (0,0)
*******T = 1/((1+4t^{2})^{1/2}) (i+2tj)
T = i at the point (0,0)
N = j at the point (0,0)
=> F = ma = m(200)jThe step that I don't understand is marked with stars (Deriving T). Since the speed is given as 10 units/sec, shouldn't that be used as |v| rather than (1+4t^{2})^{1/2}? And if |v| = (1+4t^{2})^{1/2}, doesn't this contradict the problem statement, which says that speed is constant? This makes little sense to me because we used different values for |v| throughout the problem
The source of your problem is here:
chongj12 said:
r = ti + t^{2}j
=> v = i+2tj
This parameterization conflicts with the given fact that the speed is constant. Since you are given that y=x2, you do know that
\boldsymbol r = x \hat{\boldsymbol i} + x^2\hat{\boldsymbol j}
See where this leads you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
