Calculus AB: Particle Speed Increase Intervals
  • Thread starter icecubebeast
  • Tags
    Calculus
In summary: No: increasing speed means increasing magnitude of velocity. If velocity is < 0 and is becoming < 0 at an even greater rate, speed increases; if velocity is > 0 and is becoming > 0 at an even greater rate, speed increases. Just think about velocity being > 0 if we are driving East and being < 0 if we are driving West, and think about what increasing speed means in both cases.
icecubebeast
66
The position of a particle moving along a line is given by s(t) = 2t^3 -24t^2 + 90t + 7 for t ≥ 0. For what values of t is the speed of the particle increasing?
(a) 3 < t < 4 only
(b) t > 4 only
(c) t > 5 only
(d) 0 < t < 3 and t > 5
(e) 3 < t < 4 and t > 5
d/dx [k*x^n] = kn*x(n-1) power rule
d/dx [f(x) +- g(x)] = f'(x) +- g'(x)
find the derivative:
s'(t) = 6t^2 - 48t + 90
find the second derivative:
s''(t) = 12t - 48
Since the problem is asking for acceleration "For what values of t is the speed of the particle increasing?", we find the point of inflection and find the intervals.
s''(t) = 0
12t - 48 = 0
12(t - 4) = 0
t=4
Intervals: (0,4] and [4,infinity)
We plug in a number for each interval:
s''(1) = 12(1) -48
=12 - 48
=-36
s''(5) = 12(5) - 48
=60 - 48
=12
The values of t>4 are when the speed is increasing.
The problem is that the solution to this problem is (e) 3 < t < 4 and t > 5 and I don't know why?
Hmm... Do you suppose the author of the question is thinking "magnitude of speed" rather than just speed?
A positive speed getting smaller is not speed getting bigger. This is certain. But is a negative speed getting more negative, is the speed increasing?
Is that what your teacher had in mind when he/she asked that kind of problem?
Oh, no. My physics teachers were perfect in every way. :wink:
Likes icecubebeast
How about your calculus teacher? Did he/she ask that kind of problem?
Standard nomenclature is that speed = absolute value of velocity. Your ##s'(t)## is velocity ##v(t)##, not speed. If you plot the speed ##|s'(t)|## you will see how the book's answer arises.
If you want to do it without plotting, you need to be careful about when speed is increasing; this occurs if either (a) ##v(t) < 0## is decreasing, or (b) ##v(t) > 0## is increasing. Do you see why?
Likes icecubebeast
So speed is different in that increasing speed depends only on the magnitude of the increase of speed, and not dependent on direction?
1. What is Calculus AB: Particle Speed Increase Intervals?
Calculus AB: Particle Speed Increase Intervals is a concept in calculus that involves analyzing the changes in velocity of a moving particle over time. It helps us understand how the speed of a particle changes during different time intervals.
2. How is Calculus AB: Particle Speed Increase Intervals different from regular calculus?
Calculus AB: Particle Speed Increase Intervals is a specific application of calculus that focuses on analyzing the speed of a particle. It involves using derivatives and integrals to understand how the speed changes over time, rather than just finding the overall change in position or velocity.
3. Why is understanding particle speed increase intervals important?
Understanding particle speed increase intervals is important because it allows us to analyze the motion of a moving particle in more detail. It helps us understand how the speed changes over time and can provide valuable information about the acceleration and direction of the particle.
4. How do you calculate particle speed increase intervals?
To calculate particle speed increase intervals, you first need to find the velocity function of the particle. Then, you can use derivatives to find the acceleration function, which will tell you how the speed is changing at different intervals. Integrating the acceleration function can then give you the speed increase intervals.
5. What are some real-life applications of particle speed increase intervals?
Particle speed increase intervals have many real-life applications, such as in physics and engineering. They can be used to analyze the motion of objects in space, understand the acceleration of vehicles, and even predict the trajectory of projectiles. They are also used in various industries, such as sports and transportation, to optimize performance and safety.
