Calculus based physics - Energy
The discussion revolves around solving two physics problems involving energy and forces. In the first problem, a particle's potential energy is calculated using the conservative force equation, leading to a potential energy of -24 J at x=4 m, which is identified as incorrect. The second problem involves a block dropped onto a spring, where the kinetic energy at a specific compression is to be determined using energy conservation principles. Participants emphasize the importance of understanding energy states before and after the block's drop. The conversation highlights the need for clarity in applying conservation of energy to solve these types of problems effectively.
XodoX
As a particle moves along the x-axis it is acted upon by a single conservative force given by Fx=(22-2.0x)N where x is in m. The potential energy associated with this force has the value +40 J at the origin (x=0). What is the value of the potential energy at x=4 m?
Well, you have to move it so that it is Fx= 2xdx - 20dx ( -dU/dx ) so you have this equation. Then I integrated it and got x^2-20x+C... C is 40 in this case, so you have x^2-20x+40. Since it says potential energy at x=4, I plugged in the 4 and got 4^2-20*4+40= -24. That's not correct, though.
A spring (k=300N/m) is placed in a vertical position with its lower end supported by a horizontal surface. A 1.5 kg block that is initially 0.10m above the upper end of the spring is dropped from rest onto the spring. What is the kinetic energy of the block at the instant it has fallen 0.20m ( compressing the spring 0.10m) ?
1/2kxi2=Ei=mghf - energy conservation
No idea. This equation above is a guess. I think it should be this one. If it is, you probably have to solve it for something, but I don't know. Solve for k ?
For the second question:
You're on the right track thinking about conservation of energy. What will define the energy of the system at the moment the block is dropped? What will define the energy of the system after it has dropped and compressed the spring?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
