Calculus - behaviour of functions - first derivative and the likes
dharavsolanki
Given P(x) = x4 + ax3 + bx2 + cx + d such that x = 0 is the only real root of P'(x) = 0. If P(–1) < P(1), then in the interval [–1, 1]
(1) P(–1) is not minimum but P(1) is the maximum of P
(2) P(–1) is minimum but P(1) is not the maximum of P
(3) Neither P(–1) is the minimum nor P(1) is the maximum of P
(4) P(–1) is the minimum and P(1) is the maximum of P
The answer is 1.
  • P(x) = x4 + ax3 + bx2 + cx + d
  • P′ (x) = 4x3 + 3ax2 + 2bx + c
  • P′ (0) = 0
  • c = 0
  • P′ (x) = 0 only at x = 0
  • P′ (x) is a cubic polynomial changing its sign from (–)ve to (+)ve and passing through O.
  • P′ (x) < 0 ∀ x < 0
  • P′ (x) > 0 ∀ x > 0
  • graph of P(x) is upward concave, where P′ (x) = 0
Now P(–1) < P(1)
⇒ P(–1) cannot be minimum in [–1, 1] as minima in this interval is at x = 0.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
The question is solved. That is not the problem. What I am wondering about right now is that such a logical question is too precious to be let go of without a discussion. Do you have any comments regarding either the geometrical interpretation or logical deduction of the answer?
For me, the questions are getting monotonous by the day and I have almost lost the thrill of learning because now the questions are just too clear. However, I am sure you will have a lot to discuss about it, right?
If anyone of you is a teacher - you must have had some sort of a frustrating experience on how the crystal clear logic doesn't even appeal to the students.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
