Calculus homework studying for the test: Find K such that
To find the value of K that makes the function f(x) continuous at x=0, the limit of f(x) as x approaches 0 must equal f(0). The limit of the function as x approaches 0 is determined to be 3, as the limit of (2 + sin(x)/x) equals 3. Therefore, K must be set to 3 for continuity. The discussion also emphasizes the importance of understanding limits and continuity in calculus. Overall, the key takeaway is that K must equal 3 to ensure the function is continuous at the specified point.
huan.conchito
Calculus homework studying for the test: Find K such that this is continious
f(x)=\left\{\begin{array}{cc}k&\mbox{ if }x=0\\2+\frac{Sin(x)}{x} &\mbox{ if }x\neq 0\end{array}\right
i have no clue how to find such a k that this is continious
well, from your question I see no reason why I can't choose any k that I like. Are you sure that's all there is to it?
Perhaps you are trying to make f(x) continuous?
U didn't say what the problem wa about.I assume it required that the brach function would be continuous on R...Which means point "x=0",too.
What's the condition for an univariable function defined on a domain \matcal{D}\subseteq \mathbb{R} to be continuous in a point x \in \mathcal{D}...?
Daniel.
Thats all the question says "find k such that this is continious"
Then the aswer is k\in \mathbb{R},which means an arbitrary #...
Daniel.
Thats all the question says "find k such that"
blah blah
perhaps you should elaborate on the "blah blah," verbatim if possible. I find it highly doubtful that that is what it was asking for in a calculus course.
huan.conchito said:
f(x) = {k if x=0 if x == 0
{2+(sinx)/x if x =/= 0
Well, IF the objective is to find "k" such that "f(x)" is continuous, what "k" would satisfy that condition??
HINTS #1 & #2:
1: \ \ \ \ \lim_{x \longrightarrow 0} \, f(x) \ = \ f(0)
2: \ \ \ \ \lim_{x \longrightarrow 0} \, \left (2 \ + \ \frac{\sin(x)}{x} \right ) \ = \ \color{red} \mathbf{?}
Well first like this:
f(x)=\left\{\begin{array}{cc}k,&\mbox{ if }x=0\\2+\frac{Sin(x)}{x}, &\mbox{ if }x\neq 0\end{array}\right
Not too hard, check out the syntax in the editor.
Then just do what Xanthym said to assure continuity.
Maybe the function needs to be differentiable...:wink:
Daniel.
the problem is exactly like salty dog wrote it.
and it says
"Find K such that this is continious"
2: \ \ \ \ \lim_{x \longrightarrow 0} \, \left (2 \ + \ \frac{\sin(x)}{x} \right ) \ = \ \color{red} \mathbf{2?}
HINTS #1 & #2:
Incorrect.Check that "sin" limit again.
Then u can get conclude what K needs to be...
Daniel.
the limit = 0, so K must be 0?
lim {x->0} sin x/x = 1.
so k must be 3 ?
Deleting your previous post and then reposting exactly the same thing is a rather cunning way to get an answer :wink:
Anyways, yes, that's fine.
Correct. If you are unsure why \ \ \ \ \lim_{x \longrightarrow 0} \, \left (2 \ + \ \frac{\sin(x)}{x} \right ) \ = \ \ \mathbf{1} you might have a look at the Taylor expansion of sin(x) .
Correct. If you are unsure why \ \ \ \ \lim_{x \longrightarrow 0} \, \left (2 \ + \ \frac{\sin(x)}{x} \right ) \ = \ \ \mathbf{1} you might have a look at the Taylor expansion.
You mean 3 :smile:.
We have a thread on the "sinc" limit.It has some good posts.
Daniel.
