Constant Acceleration in a Calculus Word Problem
7 replies · 6K views · last reply
preet
"An object moves so that its velocity, v is related to its position. s according to v = (b^2 + 2gs) ^1/2 where b and g are constants. Show that the acceleration of the object is constant."
I typed out the question exactly as it is. I'm confused because I don't really get what to do. To show that acceleration is constant, I need to get rid of that "s" variable in the question. Acceleration is = to d(velocity)/dt... but from the given function, you can only get d(v) / ds.
So dv/dt = dv/ds * ds/dt
But how do I find d(s) / dt? Don't I need a function that has position in terms of time?
TiA
Preet
e(ho0n3 said:
Isn't ds/dt just v?
Yes but v isn't a function of t in this case, it is a function of s
Does that matter? I mean, a = dv/ds * ds/dt = v dv/ds. If it can be shown that this is constant, then the problem is solved. There is no need to get rid of s.
Could you please show me how;
[tex]\frac{dv}{ds} \cdot \frac{ds}{dt} = v\frac{dv}{ds}[/tex]
Perhaps I'm missing something? It is late after all and I've run out of coffee
~H
dv/ds * ds/dt = ds/dt * dv/ds by commutativity and substituting ds/dt for v gives the result I gave.
Is there a flaw in my reasoning here?
Ahhhh :mad: It was so simple I missed it :frown:. My frantic scribblings on paper seem so stupid now.
[tex]\frac{ds}{dt} = v[/tex]
You reasoning is perfect e(ho0n3.
To clarify for the OP;
You were right by using the chain rule to obtain;
[tex]\frac{dv}{dt} = \frac{dv}{ds} \cdot \frac{ds}{dt}[/tex]
What you (and I) didn't spot is that;
[tex]\frac{ds}{dt} = v \Rightarrow a = \frac{dv}{dt} = v\frac{dv}{ds}[/tex]
As e(ho0n3 correctly stated.
~H
Yeah, I feel bad not catching that... it was so obvious =/. Thanks a lot for the help!
-Preet
