How can I calibrate my Ohaus cent-o-gram model 311 balance scale?
  • Thread starter Thread starter tony873004
    Balance Scale
In a classroom with Ohaus cent-o-gram model 311 balances, calibration issues arose due to mismatched parts, specifically the mass hanger and tray, which are stamped with unique numbers. The user discovered that mixing these components can hinder proper calibration, leading to one balance remaining uncalibrated. To resolve this, they suggested adding staples and paperclips to adjust the shot weight. The discussion also highlighted the importance of keeping parts together by their matching numbers for future reference. Overall, proper identification and organization of balance components are crucial for effective calibration.
tony873004
I have a classroom full of Ohaus cent-o-gram model 311. Most work fine, but a few I can't calibrate to 0. I've used the calibration screw, but even maxed out it isn't enough. I could always place a couple of pennies under the tray, but there's got to be some way to do a course adjustment. Anyone?
I've used these a LOT.
Sounds like the shot is missing from underneath the pan.
See field service manual 3-3 B:
https://www.daigger.com/Portals/0/Literature/1260D_SM_OHAUS.pdf
Thanks! I see what's going on now. I assumed they were all identical, and there would be no reason for factory-installed shot to go missing. But they're not identical. I didn't realize that each balance, its mass hanger, and its tray are all stamped with a matching 4-digit number. If you mix up the parts, you can run into trouble calibrating them. Now that I've put them all together by number, they all calibrate except one. Its parts do not have matching numbers. I'll just put some staples and paperclips in with the shot.
Cool - good catch for others resurrecting old equipment.
May be an idea to renumber or otherwise mark the odd one, for future generations, too.
I expect that somewhere you have another uncalibrated balamce, also made from non-matching parts.
Possibly this is a job for the Discworld minor goddess Anoia, responsible for Things that Stick in Drawers, Lost Cutlery, etc, ... and considering moving on to become Goddess of Hopeless Causes. :biggrin:
http://en.wikipedia.org/wiki/Discworld_gods#Anoia
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
