Can a 3-Space Be Isotropic About Two Distinct Points Without Being Homogeneous?
  • Thread starter Thread starter lark
    Homogeneity
The discussion centers on whether a connected 3-space can be isotropic about two distinct points without being homogeneous, referencing Exercise 27.16. Laura presents a counterexample using the 3-sphere (S^3), suggesting that isotropy can exist around antipodal points with a radially symmetric matter distribution that varies in density. Christian acknowledges the difficulty in visualizing this example and suggests exploring explicit scalar fields on the 3-sphere to test the validity of Laura's claim. The conversation highlights the complexities of isotropy and homogeneity in higher-dimensional spaces. Ultimately, the debate raises questions about the nature of symmetry in cosmological models.
lark
http://camoo.freeshell.org/27.16wrong.pdf"
Mistake by the author?
Laura
Latex source below for quoting purposes but the .pdf may've been edited since then.
Exercise 27.16 asks you to show why a connected 3-space can't be
isotropic about 2 distinct points without being homogeneous.
Counterexample, though. Suppose the space is $S^3$, the
3-dimensional sphere. You could think of it as the equation for
$x^2+y^2+z^2+w^2=1$.
Then let the 2 separate points be antipodal points on the sphere. For
example $x=(1,0,0,0)$ and $-x=(-1,0,0,0)$.
You could have a matter distribution that was radially symmetric
around both of these points, because a rotation around x is also a
rotation around $-x$! But it doesn't have to be homogeneous. The
matter density could go up with distance from x or $-x$, up to the
"equator" $y^2+z^2+w^2=1$.
Am I missing something, or is this exercise just wrong?
\end{document}
Space news on Phys.org
However if the universe were isotropic about 3 separate points, then it has to be homogeneous!
Laura
Laura
Do you know a proof for this?
Christian
One trivial way is to constrain the space to be flat, but that's not what your getting at here :wink:. I'm still trying to visualize your example but failing. I can see a 2-sphere being isotropic around two poles and not homogeneous, but I'm having trouble with the 3-sphere. Maybe it would be fruitful to try to come up with an explicit expression for a scalar field on the 3-sphere that would satisfy isotropy around two points without being homogeneous and see if you can do it. That might either prove you right or the problem right. I am not sure if a rotation about (-1,0,0,0) is the same as a rotation about (1,0,0,0).
In the two sphere picture the rotations are the same because you are basically spinning a globe on its axis so the rotation isn't a general rotation about a point but one around an axis.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
