Can a Function Be Self-Containing?
  • Thread starter Thread starter Trepidation
    Functions
The discussion explores the concept of self-containing functions, specifically whether a function can reference itself within its definition. The user presents an equation, f(x) = a(f(x)) + x, and successfully rearranges it to derive f(x) = x/(1-a), confirming its validity. The conversation then shifts to the challenge of isolating a function, P(w), from an equation involving another function, D(P(w)), which complicates the process. It is concluded that without knowing the form of D, isolating P(w) is generally not possible, although approximate solutions may be found using numerical methods. The thread highlights the complexities of recursive functions and the limitations of solving equations with unknown transformations.
Trepidation
First off, I'd like to say that I'm new here and not very advanced. I'm really here in the hopes of learning something, so that my mathematical tools might match up with the mathematical level of my ideas ><.
So... First off: Is it possible for a function to contain itself? For instance, here's something I've been messing around with today:
f(x) = a ( f(x) ) +x
Now... If I change the notation from f(x) to y for clarity, I get this equation, which I can rearrange in the following way:
y = ay + x
y - ay = x
y(1-a) = x
y = \frac{x}{1-a}
And, returning the notation to its original form:
f(x) = \frac{x}{1-a}
In which case, my result (without all of the work I posted above) would be that
f(x) = a( f(x) ) + x
is identical to
Is this correct, or incorrect; is there some property of functions that makes what I've done wrong? If it is correct, is there a name for this sort of "self-containing" function?
Thanks in advance for your replies... ^^
Mathematics news on Phys.org
Yes, that is valid. I would call it recursive, but I am a programmer, not a mathematician. Replacing a function with a variable in that case, though, is fine.
Alright, that's good then. Thank you. ^^
So... This is as different from what I just asked about as multiplication is from addition. But I guess it's related somehow ><.
Is it possible to solve this equation excusively for the function P(w)? What I mean is, isolate P(w) completely to one side, defining the function, without having it appear anywhere within itself. No D(P(w)) or anything like that.
And, if so, how, if you know? Or do you not know at all ><? My problem:
P(w) = \frac{N(w)}{D(P(w))}
I do not know of a way to take a function outside of another unknown function. If you know what the function “D” is, though, just replace it with the formula inside that function, and simplify.
The problem is that, if you do not know what the function D looks like, you do not know how it is transforming P(w), and therefore, you do not know how to reverse that to get it out of it… though I am not very advanced in mathematics, do not trust me that it is impossible with an unknown function! :)
In general, the answer is no. For example, let N(w)=1 , let D(u)=sin(u), and call P(w)=y,then your problem is: y*Sin(y)=1, in this case P(w) will just equal a constant which is about as simple as a function can get, but it can't be found in closed form, which I would call unsolvable.
(p.s. y can be found approximately using root finding methods, like Newtons method)
I know what function D and function N are. P is the unknown. I can't use the inverse of D, because if I do, it looks like this:
P(w) * D(P(w)) = N(w)
D^{-1}(P(w)) * P(w) = D^{-1}(N(w))
As you can see, that doesn't help at all. Which is why I ask if it can be done at all...? It might, I don't know. And if it can, I really need to know how ><.
Thanks again for your help so far!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
