Can a One-Sided Identity Element in Groups Lead to Two-Sided Identity?
The discussion revolves around the properties of identity elements in group theory, specifically whether a one-sided identity element can lead to a two-sided identity element. Participants explore the implications of defining identity elements in a group as one-sided and the potential to prove two-sidedness as a theorem.
  • One participant questions whether it is possible to define a group's identity element as one-sided and subsequently prove two-sidedness, citing difficulties in their attempts to do so.
  • Another participant points out that changing the assumption of a two-sided identity may affect the assumption regarding the existence of inverses, which is typically stated in relation to a two-sided identity.
  • A different participant clarifies that their textbook's definition of inverses does not seem to rely on the two-sidedness of the identity element, suggesting that left-handed definitions could still hold.
  • One participant proposes a weakening of group axioms to include only left identities and left inverses, providing a proof that left inverses can lead to right inverses and left identities to right identities.
  • Another participant emphasizes that the meaning of the statement regarding inverses is dependent on the definition of the identity element, indicating a potential ambiguity in notation.
The discussion contains multiple competing views regarding the implications of one-sided versus two-sided identities, and it remains unresolved whether one-sided definitions can lead to two-sided identities.
Participants express uncertainty about the dependence of certain group properties on the definitions of identity elements and inverses, highlighting potential limitations in their arguments.
HyperActive
Hi
I'm taking a math course at university that covers introductory group theory. The textbook's definition of the identity element of a group defines it as two sided; that is, they say that a group ##G## must have an element ##e## such that for all ##a \in G##, ##e \cdot a = a = a \cdot e## .
Is it possible to define a group's identity element as one-sided, and then prove two-sidedness as a theorem? Or is it an intrinsic property of group identities?
I started with a left-identity ##e \cdot a = a## and tried to prove that ##e \cdot a = a = a \cdot e## and kept hitting walls, so I though I'd better check if it's doable.
Thanks.
If you change the assumption that there exists a two-sided identity, how are you going to modify the assumption that each element has an inverse? That assumption mentions the two-sided identity.
Thanks for the reply Stephen Tashi. :)
In my book, the assumption that each element has an inverse is stated as follows: for all ##a \in G## , there exists a ##b \in G## such that ##a \cdot b = e##. That doesn't seem to rely on the two-sidedness of the identity element (and neither it seems to me does the left-handed version of the statement, for all ##a \in G## , there exists a ##b \in G## such that ##b \cdot a = e##). So other than noting that in these definitions ##e## refers to a left identity, I'm not seeing how I would need to modify them.
Could you please clarify this?
You can weaken the group axioms to require only the existence of a left inverse and a left neutral element:
(i) ## e g = g##
(ii) ## g^{-1} g = e##
Then every left inverse is a right inverse:
##g g^{-1} = e g g^{-1} = (g^{-1})^{-1} g^{-1} g g^{-1} = (g^{-1})^{-1} g^{-1} = e##
And every left neutral element is a right neutral element:
## g e = g g^{-1} g = e g = e##.
(The proof uses the fact that ##g^{-1}## is a right inverse, which I proved before.)
You can of course replace "left" by "right" and get similar results. You can't mix them, though: Having left inverses and a right neutral element doesn't suffice.
The point is that the meaning of the statement [itex]a \cdot b = e[/itex] depends on what you mean by the notation "[itex]e[/itex]".
Thank you both very much!
  • · Replies 26 ·
  • · Replies 0 ·
