Can a Rigid Body's Rotation Be Described with Only Two Successive Rotations?
A rigid body's rotation can be described using three successive rotations, such as Z-Y-X or Z-Y-Z, to achieve full generality. When using only two rotations, like Z-Y, there is a limitation in the ability to represent all possible orientations, specifically the roll axis. This means while a camera can point in any direction, it cannot achieve certain orientations, such as taking an upside-down picture without additional adjustments. The discussion highlights that while two rotations allow for significant flexibility, they do not cover all rotational possibilities. Understanding these limitations is crucial for applications requiring precise orientation control.
Barkan
I try to clearify it as much as I can, and I greatly appreciate the given answers.
Suppose that we have a rigid body. We attach a movable coodinate frame on this body.
Normally, if I perform 3 successive rotations such as Z-Y-X or Z-Y-Z (or any other 24) I can describe its rotation in the most general case.
If I perform only two rotations what will happen then? Let's suppose I only perform a Z-Y rotations (first rotate about yaw then rotate about the current pitch) what would be the loss in terms of generality? Let's say, without the 3rd successive rotation, I cannot describe the half of the ... plane and/or sphere?
Thank you very much in advance.
So you only have yaw and pitch, but no roll. Camera tripods rotate this way. You can point the camera in ANY direction, so you're not limited there. However, you cannot point the camera at an object and then roll the camera to take an upside-down picture for example. That's what you lose by only having two rotations.
If this doesn't help any, do you think you can clarify the question? What is the motivation (what exactly are you trying to do?)
I made a small mistake in my previous post. You could actually take a picture in any direction upside-down. You would do this by yawing so that you're pointing in the opposite direction, then pitching the camera so that it's inverted to look at the object.
So 0 degrees and 180 degrees are special cases. In general, you cannot take a rotated picture of an object.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
