Can a Single Gas Engine Power a Stable Quadrotor?
  • Thread starter Thread starter anchange
    Engine Gas
Designing a quadrotor powered by a single gas engine raises questions about stabilization and control. Achieving stability would likely require collective pitch adjustments for all four rotors. The feasibility of this approach is uncertain and may present engineering challenges. Further research and expert input are needed to explore this concept effectively. The discussion emphasizes the need for innovative solutions in quadrotor design.
anchange
I’m trying to design a larger Quadrotor (http://en.wikipedia.org/wiki/Quadrotor) craft that runs off of a single gas engine. Does anyone know anything about how quadrotors stabilize and how I would be able to achieve the same effects using a single gas engine for all 4 rotors? I assume it would have to be done through collective pitch adjustments? Is this even possible?
Any help would be appreciated, thanks.
Brad
Check out this link for more info...
http://hoffmann.stanford.edu/papers/Hoffmann_et_al_Quadrotor_DASC04.pdf
Chris
awesome thanks!
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
