Can a Single Photon Carry All the Momentum in Electron-Positron Annihilation?
Momentum conservation is essential in electron-positron annihilation, and it is not feasible for a single photon to carry all the momentum if the initial net momentum is non-zero. The energy-to-momentum ratio of a photon is constant (E/p = c), while the electron-positron pair has a different ratio due to their rest mass and kinetic energy. Calculating the energy of the pair involves their rest mass energy and kinetic energy, while momentum is determined using p = mv sin(theta). In the center of mass frame, the net momentum of the electron-positron pair is zero, leading to the conclusion that the resulting photon(s) must also have no net momentum. Understanding these principles is crucial for analyzing particle interactions in quantum physics.
melonhead
Hi,
I understand that momentum before and after annihilation must be conserved. However, why isn't it possible to have a net momentum not equal to zero before hand, (ex. an electron and a positron traveling head on, but at different velocities) and then just have a single photon travel in the direction of that net momentum after annihilation?
Any insight would be greatly appreciated. We just barely touched on annihilation in class, and this was bugging me.
Thanks
You need to conserve energy also. Since photons have no rest mass, a photon's energy and momentum are proportional. An electron and positron have a large ratio of energy to momentum than a single photon can possibly have.
So my question now is how would I go about proving that a single photon can't have a large enough E/p ratio?
What I was trying to do is show that the ratio for the electron-positron pair will never equal to the ratio for a single photon.
E/p of a photon is c, correct?
To calculate the Energy of the electron positron pair, do you simply use 2(mc^2+(1/2)mv^2)?
Is the momentum p=mvsin(theta) for each of the particles?
How does relativity factor into all of this?
In the center of mass frame, the electron and positron have no net momentum, so the resulting photon(s) will have no net momentum either.
What exactly is the centre of mass frame? Is the net momentum in the centre of mass frame equal to 0 in every annihilation reaction?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
