Can a Tesla Turbine Improve Paddling Efficiency on a Kayak?
  • Context: Undergrad
  • Thread starter Thread starter Dyte
    Tesla Turbine Water
The discussion centers around the feasibility of using a Tesla turbine as a lightweight propulsion system for kayaks, exploring its potential to improve paddling efficiency and alternative energy storage methods.
  • One participant proposes using a Tesla turbine to harness water flow as an energy source for a kayak, questioning whether it would ease paddling efforts.
  • Another participant provides a brief explanation of a Tesla turbine, noting its bladeless design and ease of construction from common materials.
  • A different participant mentions that while the maximum efficiency of a Tesla turbine can be 95%, practical use may result in energy losses, especially if the user must paddle to generate flow.
  • This participant also discusses the potential drawbacks of adding an impeller or propeller, which could increase drag and complicate paddling.
  • Suggestions are made about using the turbine for charging batteries for lights or other devices rather than for propulsion.
  • One participant expresses skepticism about the practicality of using compressed air for energy storage, citing concerns about efficiency and weight.
  • Another participant recommends using a car battery and trolling motor as a more efficient alternative to compressed air systems.
  • A final participant shares a resource for those interested in Tesla turbines, pointing to an online community of experimenters.
Participants express a range of views on the practicality and efficiency of using a Tesla turbine for kayaking. There is no consensus on whether it would be beneficial for propulsion, with some suggesting alternative uses and others proposing different energy storage methods.
Participants highlight various assumptions regarding efficiency, energy loss, and the practicality of different energy sources, but these remain unresolved within the discussion.
Dyte
Hi geniuses,
I have a question about a Tesla turbine.
I'm brainstorming about using a small one as a leightweight "engine" on a kayak, using the flow of the water as energy source.
First of all, I do realize that this won't run on its own in a perpetual motion style.
But my question is, will this help in any way or ease the paddling, or will it just do nothing whatsoever?
Thanks for your time!
what's a tesla turbine?
ok, so from what I've read the max efficiency obtainable from a tesla turbine is 95% under perfect conditions. That means a 5 % loss of energy. It may be useful if you were paddling against a current or if you had a way to generate a flow through the turbine without work from yourself, otherwise if you have to paddle to get the flow, the efficiency makes it redundant. In other words, you'd have to put more energy in than you'd get out.
also, adding an impeller or propeller to turn the energy created from the turbine into energy that will give your kayak motion will add drag when you are paddling, which would make things harder than they are now. If you could mount it like an outboard motor that can be lifted out of the water while getting up to speed and then put in the water to be used for propulsion, that woud help. Bear in mind you'll also be adding more weight to your canoe that you'll hae to lug around.
You could use it for charging a battery maybe for lights during night time fishing trips or a radio (or charger for your ipodski) if that's useful.
Thanks for the insights.
It appears that this isn't be the way to go after all.
I was also considering compressed air, but I have no idea how long a bottle (of say one liter) will last. It won't be feasible to haul around 20 pounds of air if it will only last one hour :-).
However, great idea to use it for recharging! I'm new to this so for the most part I'm still groping in the dark but I'm going to dive into it right away.
Thanks
Unfortunately, air tanks are not a very efficient way to store energy. You'd be better off with a car battery and a trolling motor.
  • · Replies 38 ·
