Can an Inductor Reduce Voltage?
  • Thread starter Thread starter Thayalan
    Inductor Measure
An inductor can reduce voltage through its reactive impedance, which interacts with other circuit impedances to create an AC voltage drop. To measure an inductor's value, an LCR meter is the simplest tool, but alternatives like a signal generator, resistor, and oscilloscope can also be used. The phase shift observed in a resistor-inductor series circuit indicates when the inductor's reactance equals the resistor's value. Additionally, an inductor has a DC resistance that contributes to voltage drops in both AC and DC circuits. Understanding these principles is essential for effective circuit design and analysis.
Thayalan
hi guys... i quiet new here...
just wondering ,.. how to measure a inductor...
TQ
Welcome to the PF. There are a number of ways to measure the value of an inductor. The simplest, of course, is to us some instrument like an LCR meter. Those instruments impress an AC waveform (typically 1kHz or 10kHz or 100kHz) across the inductor, and measure the resulting current.
If you don't have an LCR meter or other AC impedance-measuring device, you can do it youself with a signal generator, a resistor and an oscilloscope. Use the fact that you will get a 45 degree phase shift through the resistor-inductor series combination when the reactance of the inductor equals the value of the resistor. Are you familiar with how the reactance of the inductor varies with frequency?
Can an Inductor reduce voltage
Yes, in several ways. Here is some basic info on RLC circuits:
http://en.wikipedia.org/wiki/RLC_circuits
An inductor has a reactive impedance, which can interact with other impedances in a circuit and provide an AC voltage drop. A real inductor also has an associated DC resistance (DCR), which will act like any other resistor and provide a DC and AC voltage drop when a current flows through it. You usually will chose an inductor that has a small DCR compared to its reactive impedance at the frequencies of interest, though. Make sense?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
