Austin0 said:
The definition I understand of "teleportation" is moving from one location to another without passing through intervening locations, for example in quantum tunneling.
Hi Thank you .I am in complete agreement. That is exatly the point.
I have the same understanding of what is meant by teleportation. I also don't consider it a very plausible possible reality but in an imaginary thought experiment it can be well defined so the same conditions pertain as if it was a reality.
Let me give a crude sci-fi example of what I mean. Suppose a human could be frozen in liquid helium and later thawed as the cryonics industry is attempting. The frozen person could be dismantled atom by atom here with the relative location of each particle noted. That data could be emailed to Mars and the person reassembled using locally sourced atoms. When thawed, they would have traveled between the planets without passing through the space between them in physical form. That technique could be extended to distant stars if unmanned probes could be sent there to build the receiver. That would essentially provide "teleportation" at the speed of light.
In SR, there is no such thing as absolute simultaneity so if your form of teleportation existed, SR would not be applicable, you would need to discard SR for some other theory that supported absolute simultaneity.
Which, as you say would mean that SR was not applicable.
The assumption of absolute time would mean SR is philosophically wrong (IMHO) though still mathematically valid, the assumption of teleportation does not.
That to simply assign the time according to coordinate simultaneity, isotropically to its arrival anywhere within a frame, is to implement an implicit assumption of absolute synchronization of the clocks in that system. Which we know is not a valid assumption in SR.
Without this initial assumption and the consequent spacetime location of its arrival or hypothetical arrival, in the initial frame, there is no basis whatsoever for any prediction of where or when it might arrive in another frame.
WOuld you agree?
Not quite. The question of "where" is easy, you arrive wherever the receiver is located. If the teleport works at or below the speed of light, normal physics applies. If it is FTL then the actual speed in any frame tells you when and the where/when coordinates can be transformed by Lorentz as usual, you just get an FTL result in all frames, but as has been discussed, you also get the ability to move back to your own past.
I agree the idea of a universal simultaneity according to Galilean clocks was actually eliminated by SR but the idea of restricted absolute simultaneity as, for exsample EPR , is not mentioned or excluded.
As far as my understanding of the QM concept and the current state of experimentation it appears to be (or at least promise) a means of establishing absolute simultaneity between two locations.
harrylin said:
From Bell's theorem and the current status of experiments one may infer the existence of an absolute simultaneity, but other explanations have been given.
I don't follow that. For example, you can measure the state of two entangled particles at spacelike separated events and find they are correlated but that doesn't define a surface of simultaneity. You know when you measure a particle but you cannot distinguish between (a) whether you are the first or second to make a measurement and (b) whether the value was determined by your measurement or had already been forced some time earlier. This means that although it appears to imply there is a linkage which is FTL, all FTL values are equally valid, and since no information is passed, SR is not invalidated that way either.
Obviously, an absolute frame is one approach to understanding the behaviour of entangled systems but I don't think it can be "inferred", only postulated.
I myself, don't see this as a problem or a detraction from SR as the phenomenon doesn't entail motion per se , through spacetime, so is outside the domain of SR or perhaps more correctly would simply be a physical phenomenon within SR but would not necessarily change the structure.
Thanks
If an absolute frame defines the rate of physical processes, then SR becomes only an emergent description of something else IMHO, but nothing I've seen so far provides any evidence for that.
Incidentally, this experiment looks as though it could send data into the past (by binary modulation of Victor's decision measured by correlation of Alice and Bob's results) which, combined with the "teleportation" method outlined above would allow us to visit the past any time after the first receiver is built:
http://www.sciencedaily.com/releases/2012/04/120423131902.htm
The preprint is available here:
http://arxiv.org/abs/1203.4834
