Changing Oxygen Atoms: Is It Possible to Alter Element Composition?
The discussion centers on the possibility of changing an oxygen atom into another element by adding a proton, a process known as nuclear transmutation. Participants clarify that while nuclear fusion can occur in stars, it is not feasible for individuals to perform such transformations. Specifically, adding a proton to an oxygen atom to create fluorine is complicated by the absence of a stable isotope of fluorine with eight neutrons. The conversation also touches on the existence of multiple isotopes of oxygen, but the focus remains on the challenges of achieving stable transmutation in this context.
Leronira
As stated in the title. Is it possible?
Say for example, if I have an Oxygen Atom.
Is there anyway I can add in another proton to this Oxygen atom such that i can change it to some other element?
Chemistry news on Phys.org
What you are describing is nuclear fusion and yes it is possible...just not for an individual. I'm not sure if it has been tried by scientists with oxygen, but it happens in stars (that's where large atoms come from).
hmm...Thanks...
Ill go do more study on nuclear fussion then..=D
What you are looking for is called nuclear transmutation.
Not for oxygen, since there is no stable isotope of F with 8 neutrons.
Why should that be a problem - there is more than one isotope of oxygen too.
True. I assumed the OP was referring to the most abundant one.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
