Programs Can i get a masters of engineering with a physics degree?
Combining physics with electrical engineering, particularly in robotics, is a feasible path for those currently studying physics. Pursuing a master's degree in electrical engineering after completing a physics undergraduate degree is a common route. It is beneficial to take electives such as Signals & Systems and Control Theory during the physics program to facilitate this transition. Strong programming skills and familiarity with embedded systems will also enhance readiness for advanced studies in engineering.
nikos18523
i have been studying physics since last year... and i considered that i would like to combine engineering ...and especially ,electrical engineering(robotics ) ... i don't have the opportunity to change school right now so i considered if i can combine them at the future with a master degree . thank you for your help
You're talking to one right now.
BS in Math and Physics
MS in Physics
MA in Electric Vehicle Engineering
And another.
BS Physics
BS Engineering Physics
MS Electrical Engineering
If you have time take Signals & Systems and Control Theory as electives in your Physics BS. That will make the transition much easier. I am assuming your programming skills are sufficient. Also Embedded systems is easy to pick up.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
