Can Regular Paint Be Used on Bronze Items?
  • Thread starter Thread starter rollingstein
The discussion revolves around the use of paint on bronze items, particularly in the context of equipment such as shipboard fire pumps. Participants explore whether bronze items can be painted, the reasons for painting them, and the compatibility of regular paint with bronze.
  • Some participants question whether bronze items are typically painted or if they can be painted at all.
  • One participant notes that items may be painted for protective reasons or to indicate their function, as seen in the case of a fire pump.
  • There is a discussion about the variety of colors used for painted items to signify different piping systems.
  • A participant asks if "regular" paint is suitable for use on bronze or if specific types of paint are required.
  • Another participant suggests that, to their knowledge, bronze and "regular" paint are compatible.
Participants express uncertainty about the typical practices regarding painting bronze items. While some acknowledge that painting can serve functional purposes, there is no consensus on the compatibility of regular paint with bronze or the prevalence of painted bronze items.
The discussion does not resolve the question of whether specific types of paint are necessary for bronze, nor does it clarify the implications of using regular paint on bronze items.
rollingstein
Are bronze items typically painted? Or can they be painted?
I'm used to seeing native bronze in its native color in equipment but in one context someone sent me a Photo of a shipboard fire pump that is supposed to be bronze. Is this likely to be bronze? Of course, I'm looking at other more rigorous ways to check this claim but just as a first approximation what do people think?
Six of one, and half dozen of the other.
Ok, thanks. So to find a piece of equipment in bronze that has been painted over isn't unusual?
Things are painted for various reasons. Sometimes, the paint furnishes a protective coating, to keep the material underneath from being degraded by exposure to the elements. Other times, as in the case of this fire pump, the paint and pigment serve to identify that out of the various pumps on this ship, this pump is part of the fire-fighting system, and you can determine this at a glance without having to trace the system manually or consulting a set of plans.
If you look around, you'll probably find that such items are painted in several different hues, each of which indicates to which piping system that item belongs.
Understood! Thanks.
So, does "regular" paint work with bronze or are there a special class of paints for bronze?
rollingstein said:
Understood! Thanks.
AFAIK, bronze and "regular" paint, whatever that means, are compatible.
  • · Replies 74 ·
