Can rotation wt, lift leverage wt
  • Thread starter Thread starter Newtons-law
    Lift Rotation
The discussion explores the mechanics of a rotating wheel with weights and their potential to create leverage. When a 50 lb weight rotates to the bottom of the wheel, it can exert enough force through a bar attached to the shaft to lift a 15 lb weight on a teeter-totter, provided the moment created by the bar exceeds that of the weight. Additionally, the scenario involving a 10 lb ball rolling down a 45-degree tube raises questions about whether it can cause a sliding motion when it hits a stopping point under 40 lbs of pressure. The mechanics suggest that if the force from the ball's impact is sufficient, it could indeed cause the tube to slide. Overall, the principles of leverage and momentum are central to understanding these scenarios.
Newtons-law
Question: On one side of a wheel there is 50 lbs of weight, if the wheel is released the weights would rotate with the wheel until the weights where at the bottom and stop. Let's say this wheel has a shaft in the middle of the wheel that turns as the wheel does, if you put weights on one side of the wheel, when the wheel is released the the wheel and shaft turns until the weights stop at the bottom. Ok on the shaft there is bar welded to it, a long enough bar to use for leverage as the wheel turns {like a fan blade attached to its shaft}. Now let's say we have a balance scale or a teeter totter with 15 lbs at one end. If 50 lbs of weight in rotation on a wheel is pushing down with the attached bar, could the bar push down on the other end of the teeter totter that has no weight and lift the 15 lbs of weight on the other end of the teeter totter?
Certainly if the bar provides a moment sufficient to exceed the moment applied by the 15 lb weight. Basically shaft through the wheel and the bar behave likd a cam shaft.
I'm not completely sure I understand your scenario (a picture would help), but yes, you can use a lever to lift a 15 lb weight with a 50 lb weight.
Ok let's say we have a ball weight or round weight of 10 pounds and roll it down a tube or half tube that is 5 ft long and at a 45% slope and at the end of the tube there is a stopping point. The end of the tube or the place where the ball stops is attached only by bearings that slide forward and after 2 inch's a metal lip will stop the forward motion of the small portion of the tube that slides. If there is 40 lbs of pressure an inch wide on top of the tube and the 10 lbs ball hits the end of the tube that can slide forward, {will it slide}.
45 degree slope
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
