prshptl
- 7
Hi Russ,
Could you help me with this question
An electric motor drives a machine through a reduction gear ratio of 9 to 1. The masses rotating with the motor shaft have a moment of inertia of 0.5kg m2 and the masses rotating with the machine shaft have a moment of inertia of 38kg m2. A constant torque of 100Nm resistst the rotation of the machine shaft and the efficiency of the reduction hear is 95%. The motor can develop a maximum torque of 27Nm.
Determine the power the motor develops when the machine shaft is driven at the uniform speed of 150 revmin-1
Determine the least time requred for the speed of the machine shaft to increase from zero to 150 rev min-1
If the gear ratio were altered so as to give the machine shaft the greatest possible angular acceleration, what would then the gear ratio be?
Gear ratio-angular speed of high-speed shaft/ angular speed of low speed shaft.
