Can someone prove this series converges?
  • Thread starter Thread starter AxiomOfChoice
    Series
The series \(\sum_{n=3}^\infty \frac{3}{n^2 - 4}\) can be analyzed for convergence using various methods. One effective approach is to rewrite it as \(\sum_{n=3}^\infty \frac{4}{n^2 - 4}\) and apply a telescoping series argument. The limit comparison test with \(\frac{1}{n^2}\) is also suggested as a simpler alternative to demonstrate convergence. The series behaves like \(\mathcal{O}\left(\frac{1}{n^2}\right)\) for sufficiently large \(n\), confirming its convergence. Overall, both the telescoping method and limit comparison test provide valid proofs of convergence for the series.
AxiomOfChoice
<br /> \sum_{n=3}^\infty \frac{3}{n^2 - 4}.<br />
All the standard approaches I've used have failed. I think the integral test will work, but it's a bit messy.
Mathematics news on Phys.org
Well it's clearly equivalent to testing for convergence of:
\sum_{n=3}^\infty \frac{4}{n^2-4}
so let's do this instead (the constants turn out nicer). We note:
\frac{4}{n^2-4} = \frac{1}{n-2}-\frac{1}{n+2}
You can use this and a standard telescopping argument to show that it converges.
Not actually doing this, but couldn't you do the limit comparison test with 1/n^2? Maybe it's not as easy as it seems.
Yes this would work just as well. I used my approach mainly because it also gives you the actual limit (whether you care for it or not), and it uses more elementary tools.
I guess the limit comparison test is actually a bit easier to carry out now that you point it out and it may have been the intended solution.
As already pointed out, you could use the comparison test, and the fact that :
\frac{3}{n^2-4}={\cal O}\left(\frac{1}{n^2}\right),
for n>k (in this case k=4 would work).
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
