employee #416 said:
Heh, don't babble to me about what I'm denying and what I'm accepting. In the end, you are right though.
The only one here babbling is you.
Time contraction is also an illusion. Time only seems slower at high velocities, because our eyes can't measure things as fast as it can moving at non-relativistic speeds. This lag in the eye's calculation gives the illusion that time is running slower. This may not be relevant, but I'll take a stab at it. Turn on a strobe light. How does everything look in motion? Slower than it actually is, eh? Our eyes are tricked. We measure things only if visible. If things go in and out of visiblity the eye measure slower than normal. This is an illusion, but we know that time is the same, right?
I repeat: Our eyes have nothing to do with it. When time dilation is measured in muon decay, the time of creation is recorded, and the time of decay is recorded. The particle lives longer in the lab frame than it does in its rest frame. And no, the decay is not too fast for the equipment.
Particle phyisicists use time dilation every day to prolong the lifetime of unstable particles so that they can study them. But once again, here you are, the arrogant, ignorant internet bozo, thinking that you know better than the people who work with it every day, when you have never even studied it once.
How can we rely on equations, that are derived from methods our eyes use for measurements? Our eyes do not measure everything accurately. If something is too fast for our eyes to measure, our eye distorts it. If an object is not moving, our eye is not accurate in measuring any dimension of that object. It's all estimated, until a tool for measuring is pulled out for clarity.
Our eyes
don't take the measurements in modern physics. Why are you ignoring me?
An object has a length of 100cm.
Correction: An object has a length of 100cm in its rest frame.
It is traveling at relativistic speeds. Let's make that speed .95c. It appears to be shorter or is shorter?
It is shorter in the frame of the person watching the object fly by. It is still 100 cm in its rest frame.
No one cares what you would go with. All experimental confirmations of SR contradict you.
That's why you are a crackpot.
Length does not just disappear into thin air.
The universe is not oblgated to behave according to your preconceived notions.
The true length will ALWAYS be there.
Correction: There is no "true length" of any object.
The time experienced by that moving object is the same as a person in a difference reference frame. It just seems slower.
No, it is slower.
No, I'm going to correct you.
Again, your arrogance is absolutely staggering. What on Earth makes you think you know anything about this? You have very clearly not studied it.
It only appears to be shorter. The physical length of an object traveling at relativistic speeds is always there.
Wrong. There is no preferred frame of reference, and so there is no true "physical length" of an object. You are just clinging to a faulty view of space and time that was used by Newton and is now known to be false.
By true lenght, I'm referring an object measured while on the ground or table.
That is called the proper length, but there is nothing special about it. The idea of the length of an object has no meaning apart from specifying its state of motion.
They are measruing wrong. No length is lost due to motion. That's just stupid.
Oh, well now I'm convinced.
I'll just scrap all of those experimental tests of relativity because, "that's just stupid".
Learn to formualte an argument, kid.
Magically that length returns when an object is decelerated to non-relativistic speeds. No, it was always there.
Wrong. The length contraction formula applies at
all speeds, not just relativistic speeds.
I'm pretty sure this has to do with the human eye.
I've already told you this is wrong, so the question is, why the hell are you persisting in it?
TRIANGLES! The whole formula is derived from the transformation of triangles.
You are hopeless.
First, you ask me for a link that contains the derivation of these phenomena, and I gave it to you. You have
obviously not even looked at it, because it very clearly shows how the Lorentz transformation is derived from the postulates of relativity and Maxwell's electrodynamics.
"TRIANGLES!" Pfffft. Get a clue.
I'm pretty sure if you were to mess with it, you could get at the method the human eye uses to measure things.
I'm absolutely sure that you have no idea of what you're talking about.
It isn't an eye trick.
Ok, take an object with two points. The point at the head end is point A, while the point at the back end is point B. This object, at rest, has a length of AB. Give this object a velocity that is non-relativistic, and your eyes notice no drastic affects in measuring the length. Give it relativistic speeds, and your eyes notice a huge difference. When it tries to calculate the distance from A to B it is smaller than what the distance is at rest. When point A crosses the eye, almost immidiately point B crosses the same path A has just crossed. Thus making measurment SEEM contracted. No length contraction is taking place.
Wrong. Look at the Lorentz transformation, and you'll see no reference is made to human eyes, human minds, or the means of measurement.
You keep posting this same garbage, and I keep telling you that it is not reflective of relativity at all. Why do you do that? It is just not rational. You say that you want to be a member of this Forum, and you know that we do not allow unsubstantiated nonsense here. So why is that all you ever post? It makes no sense.
