B Can Time Travel Take Us Back to the Big Bang?
  • B
  • Thread starter Thread starter Aashish sarode
    Time Travel
Aashish sarode
1.if we assume BIG BANG as frame of reference for time then how could one go to past ?
2.if i travel the time and go to past at the time of BIG BANG, at what place i will be?
3.why the speed of light is same for everything(moving or stationary)?
3.and what will be the apparent speed of light beam for another beam of light or particle moving at speed of light?
1. We have no evidence that it is possible to travel in time. Also, it doesn't make sense to refer to the big bang as a frame of reference.
2. We have no evidence of the existence of anything before the big bang. So even if you could travel in time it's not clear that there is such a destination.
3. It just is. We only justify it by saying we can predict stuff perfectly if we assume that, and we get all sorts of problems if we don't
3 (again) There is no such perspective. It is self-contradictory to attempt to describe it because light would have to be stationary and moving at 3x108m/s at the same time.
Time, as we understand it, began at the big bang. So you're asking what would something that doesn't exist be like if it did exist. There's no way to answer that.
If you're wondering where the big bang occurred, the answer is right where you are now. And right where everything is now. The universe didn't expand into an already existing space. Space itself expanded. And continues to do so.
It's difficult to answer "why" questions because every answer is just met with another "why". One way to look at it is like this. The laws of physics, as they exist now, are stated in such a way that a state of rest is equivalent to a state of uniform motion. With no way to distinguish experimentally between those two states, the speed of light has to be the same to all observers. Thus the laws of physics treat those two states as being equivalent.
Experiments overwhelmingly confirm that these laws of physics work.
The laws of physics that I mentioned above put a strict upper limit on the speed of an observer. Observers cannot reach the speed of light. So again, you're asking what would something that doesn't exist be like if it did exist. You might find an answer to such questions somewhere, but not within the body of knowledge known as physics.
If something didnt exist before big bang then in which thing the universe is expanding and which things made big bang to happen? Also according to Mister T there was nothing before big bang so what made energy to convert into mass?
The universe doesn't need to be expanding into anything. You can write a complete description of a 4d object where each 3d "slice" is bigger than the one on one side of it and smaller than the one on the other side without referencing anything outside - it's called the Friedmann-Robertson-Walker (FRW - sometimes Lemaitre gets a look in and you see FLRW) solution to Einstein's equations.
It isn't clear that anything caused the big bang - our notions of causality are all based on our experience inside the universe. There's no particular reason why they should apply outside the universe, even assuming that there's anywhere outside the universe to talk about.
Essentially, it isn't clear that your questions are meaningful. And even if they are, we don't yet have the knowledge to answer them.
And on that note, this thread is closed.
Likes weirdoguy
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
