Can virtual produce anti-gravity?
wangyi
Perhaps it is a stupid question, but really confuses me.
In QFT, virtual particles can be produced from vacuum, say, (M,0,0,0) and (-M,0,0,0)
In Einstein's theory, if we consider the (-M,0,0,0) virtual particle, make it's energy-momentum tensor and solve the Einstein equation, and take the limit of weak field, we find the potential it produces for other real particles is positive, so it gives a exculsive force.
Is it right? if so, can the negative-energy particle fall into the black hole? because if the negative energy particle has anti-gravity, it can never go into a place that have infinity high potential energy.
Thank you!
When a particle-antiparticle pair is created from vacuum both have positive energies. However, there is a heuristic way to explanation Hawking radiatio invoking negative energies viewed by observers at infinity (I remember I read something in Schutz). Anyway, consider a particle of negative energy at the event horizon. The force between the black hole and this particle would be repulsive. However, since the particle has a negative (inertial) mass, it would accelerate in the contrary direction to the force and it would fall into the black hole.
No, virtual particles cannot produce anti-gravity. Virtual particles are not real particles, they are a mathematical concept used in quantum field theory to describe the interactions between real particles. They do not have physical properties such as mass or energy, and therefore cannot produce anti-gravity. The concept of negative energy particles is also a theoretical concept and has not been observed in experiments. It is important to remember that theories and mathematical equations are models that attempt to explain and predict the behavior of the physical world, but they are not the same as the physical world itself. So while it may seem confusing, it is important to distinguish between theoretical concepts and actual physical phenomena.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
