Can we predict the color that will be perceived by the eye?
  • Context: Undergrad
  • Thread starter Thread starter penguin007
    Color Eye
The discussion revolves around the predictability of color perception when illuminating the eye with different monochromatic light sources, characterized by their wavelengths and intensities. Participants explore the complexities of color perception, including subjective experiences, color mixing, and the influence of surrounding light conditions.
  • Some participants question whether it is possible to predict the color perceived by the eye when illuminated by two different monochromatic lights, suggesting that subjective experience (qualia) complicates this prediction.
  • One participant proposes that combining blue and red light results in purple, and asks if a specific percentage of each wavelength could be equated to a single wavelength.
  • Another participant discusses an experiment demonstrating that the perceived color can change based on the intensity and combination of light sources, indicating that context matters in color perception.
  • Some participants mention that LCD screens use three monochromatic lights but have a limited color space compared to human vision.
  • There is a discussion about how the brain interprets colors from different combinations of light, with examples of red and green light producing the perception of yellow.
  • Questions arise regarding the definition of saturation and hue for monochromatic light sources and the relationship between RGB values and chromaticity diagrams.
  • Participants explore the implications of having multiple light sources and how they can create similar perceived colors despite differing wavelengths.
Participants express differing views on the predictability of color perception, with some arguing that it is possible under certain conditions while others emphasize the subjective nature of color experience. The discussion remains unresolved regarding the extent to which color can be predicted from monochromatic sources.
Participants note limitations in understanding how color perception is influenced by surrounding light and the complexity of defining color in terms of intensity and wavelength. There are also unresolved questions about the relationship between RGB values and perceived colors.
penguin007
Hi,my question is the following:
Supposing that we light up the same surface of an optical system (the eye) by two different monochromatic lights (each one characterized by a wavelength and intensity): Can we predict the color that will be perceived by the eye?
Thanks for your help.
Science news on Phys.org
Are you referring to qualia? Whether we can predict the subjective experience of a wavelength?
If so then the answer is no we can't. Although if you have already experienced some monochromatic light source and you then illuminate your eye with another source of similar wavelength then we can say that we will perceive a similar colour, say a different shade of red for example.
Yet, we know that if we light up the eye with two monochromatic lights (let's say blue and red) both of the same intensity, then the color perceived will be purple; if the intensity of blue is more important than the one of red, then the color will be perceived as "dark purple"...
Is it possible to predict the color we see (by telling "x% of blue(435nm) + y% of red (700nm) is equivalent to a light of z nm")?
CONE CELL makes colorful image in blazing light!
Sometimes, but not always. For example, how does one generate pastel hues from monochromatic sources? Or brown?
The answer to this question is also dependent on what else is withing your field of view.
Here's an experiment we did in physics class:
Have a room that can be completely darkened.
Have 3 light sources of variable intensity, one red, one green, one blue.
Have a 6' by 6' grid of 36 different colored squares on a wall.
Have a photometer to measure the light reflected off individual squares.
Now view the grid with an equal intensity of light from the 3 light sources shinning on it. You should see it in it's natural color. Measure that reflected light with the meter and note the measurement, for one of the squares.
If you now cover all but that one square, and adjust the 3 source lights until the color of the 1 square appears different, then remove the covering so that your eyes can compare it to it's neighbouring square it will return in appearance to it's natural color.
You can now measure the light reflecting off that 1 square and confirm that it's peak wavelength differs from when it was under even lighting from the 3 sources.
So, you can in fact see the same color in the 2 cases, when seeing different wavelengths of light.
Don't LCD computer screens use 3 monochromatic lights in each pixel?
Yes, but the color space accessible by LCD/triphosphor displays is a much smaller subset of the total color space accessible to our eyes.
I find this so interesting. Shine red light and green light into the eye simultaneously, the red light stimulates the red cones, the green light stimuates the green cones, and then the brain's interpretation is "I see yellow." Shine only yellow light into the eyes, it stimulates both the red cones and the green cones, and the the brain's interpretation is "I see yellow." The same sensation in both cases. To find out whether the light is yellow, or whether it's a mixture of red and green, you can't tell by looking at it, although you could tell by directing the light through a prism to see what colors come out the other side. The prism would separate red and green. If it's yellow, it comes out without any change.
penguin007 said:
This link can also be interesting:http://hyperphysics.phy-astr.gsu.edu/hbase/vision/cie.html#c2";
However; I can't understand what do the numbers in the table represent (eg.Red=191(red),27(green),75(blue)).If anyone has an idea...
In computer graphics, colors are specified with 3 numbers ranging from 0 to 255 with using RGB mode. Those numbers represents the intensity of the colors red, green and blue with three 0s meaning no intensity, hence black. Three 255s would be max intensity for each hence white.
And what's the link between these numbers and the chromacity diagram?
There's 2 ways you can specify a color, with a computer display.
1) RGB = red, green, blue
2) HSB = hue, saturation, brightness (alternately HSL or HSV)
http://en.wikipedia.org/wiki/HSL_and_HSV
The wiki entry explains how to convert between the 2.
It's called a color space, it defines the coordinates of the R,G,B points on the color triangle and so the range of colors that you can show
- as well as the mapping of RGB->perceived color.
There are two main ones, aRGB (adobe) and sRGB (everyone else) see http://en.wikipedia.org/wiki/SRGB
Thanks a lot for your help that has been very useful to me!
I've one more question:
Is it possible to define the saturation and the hue of a source of light such as a torch or a monochromatic source?
A monochromatic source would have a single hue and a sat/value depending on the power.
A black body source (light bulb) is usually defined by color temperature http://en.wikipedia.org/wiki/Color_temperature
It's interesting that lots of stuff that was only of interest to a very small set of optics engineers is now displayed on the back of everyones digital camera.
I've one last question:
Suppose we have two monochromatic light's sources respectively of intensity I1 and I2. Let's say we make the lights of these sources partially reflected by a surface of glass and that x% of the light 1 and y% of the light 2 are reflected:can we say that the intensity of the reflected light is I=x*I1+y*I2?
Yes, this is what I found interesting too. As far as I know, you could have more than 3 different light sources of different monochromatic light. In fact, the more light sources you have, the closer you can get to a full spectrum. But what I find very interesting, is that means there should be an almost infinite number of different spectrums that, when we observed them, they should all appear the same (ie: produce the same experience of color in the brain).
  • · Replies 207 ·
15K
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 36 ·
11K
  • · Replies 28 ·
