Can You Calculate Heat Conductivity with These Simple Variables?
  • Thread starter Thread starter TheAnt
    Conductivity Heat
Calculating the temperature on one side of a material requires knowing the thermal conductivity, thickness, and temperature on the opposite side. The thermal conductivity formula is essential for determining heat transfer, commonly used in designing heatsinks. To find the rate of heat flow, both temperatures are needed, but if heat is applied externally, the rate can be known in advance. The equation for heat transfer involves the rate of heat transfer (Q/t), thermal conductivity (k), temperature difference (T1 - T2), and thickness (d) of the material. Understanding these principles allows for effective calculations of temperature and heat transfer in various applications.
TheAnt
Is there an easy way to calculate the temperature on one side of a material if we know what material it is, the thickness of it and the temperature on the other side. Basically can we calculated the heat transferred through a material if heated.
Thank you
Science news on Phys.org
Thank you
are you not familiar with the thermal conductivity formula ?
much used in designing heatsinks for electronic equip and other things
have a play in google :smile:
Thank you
If you want to know the rate of heat flow, you need to know the temperatures on both sides. If you want to know the temperature on one side (knowing the temperature on the other side), you need to know the rate of heat flow.
Thank you. How would you know the rate of heat flow beforehand? Dont you need to know both temperatures to find heat flow
thank you
You would know it if you were forcibly applying it with a heater.
I think this will help you. As it help me too.
In equation form, it looks like this.
Q over t is the rate of heat transfer - the amount of heat transferred per second, measured in Joules per second, or Watts. k is the thermal conductivity of the material - for example, copper has a thermal conductivity of 390, but wool has a thermal conductivity of just 0.04. T1 is the temperature of one object, and T2 is the temperature of the other. Since it's a temperature difference, you can actually use Celsius or Kelvin, whichever is most convenient. And d is the thickness of the material we're interested in.
