Can you make a battery out of light slowing materials?
The discussion explores the feasibility of using light-slowing materials to store solar energy for nighttime use. Participants highlight that while slowing light is theoretically possible, significant energy loss occurs during the process, making it impractical for energy storage. Current technologies do not support efficient storage of sunlight in this manner, and converting photon energy into a more manageable form, like electricity, is deemed more efficient. Alternatives like space-based solar power are suggested as more viable solutions. Overall, the consensus is that using light-slowing materials for energy storage is not plausible with existing technology.
arusse02
I've read about light slowing materials, and I'm wondering if you could slow down light enough, could it be used to say store light from the sun during the day so solar panels could work at night? Or would it not work because the process of slowing light down gradually absorbs some of the light/too much energy would be lost over a 12 hour period? Does it seem plausible to store sunlight this way?
it doesn't slow materials
It slows IN materials ( aka different mediums
not with any known technology that I am aware of
Well if you could build a lossless material, I don't know that you'd gain that much. Take a look at the table of indexes for some materials. https://en.wikipedia.org/wiki/List_of_refractive_indices
It looks like the highest one is Germanium, where light travels 4 times slower. So if light normally takes 8 minutes to get here from the Sun... If you could build a 93 million mile column of germanium, then that light will take 32 minutes to reach us. Not much gain there. I guess someone could coil some fiber optic, but how much is that going to cost, compared to the gain?
How about put some satellites up to collect the energy and beam it down to us? Something like this- https://www.energy.gov/articles/space-based-solar-power
Wikipedia has much more efficient examples:
In 1998, Danish physicist Lene Vestergaard Hau led a combined team from Harvard University and the Rowland Institute for Science which succeeded in slowing a beam of light to about 17 meters per second,[1] and researchers at UC Berkeley slowed the speed of light traveling through a semiconductor to 9.7 kilometers per second in 2004. Hau and her colleagues later succeeded in stopping light completely, and developed methods by which it can be stopped and later restarted.[2][3] This was in an effort to develop computers that will use only a fraction of the energy of today's machines.[4]
In 2005, IBM created a microchip that can slow down light, fashioned out of fairly standard materials, potentially paving the way toward commercial adoption.[5]"
https://en.wikipedia.org/wiki/Slow_light
So it looks like its been slowed significantly more than only 4 times. Not sure of the losses here or the power or technique required to slow light, but it seems like if they got to 17 m/s, then can probably do much better.
light slowing materials means the same thing as a material that slows light.
Are the examples I included from wikipedia in the post above usable?
yeah, I guess you could interpret it that way :wink:
It depends on what light is considered to be, and what is meant by slowing it down.
How many photons are being slowed down, or stored at the time?
It takes many photons to generate significant energy.
One watt needs about 1019 photons of light per second.
How can you store all those individual photons, then release them later as you need them?
Well, it would be more efficient to take the photon energy and convert it - for the purpose of storage - to a form that doesn't start off moving at the speed of light. You wouldn't have to downshift the speed. This happens pretty seamlessly with electrons. You could store them in some sort of battery.
:rolleyes: Doesn't anybody remember the SF story Light Of Other Days ?
And, if the pane of "glass" in front of the PV cell allowed some light through quickly, and slowed the rest down for 12 hours or so, you'd need fewer batteries. Fine tune it with different speeds and you could match throughput to anticipated electricity demand and not need a battery at all.
Still, it would probably be easiest to imagine for a skylight or home-heating system. Or, a flashlight that if you left it out for a few days, could be used to incinerate things.:biggrin:
Likes Nik_2213
Funnily enough, I remember 'slow glass' from one of the prequel tales, where cars fitted with a 'new, improved' type of laminated safety glass suffer a spate of weird, apparently inexplicable collisions. The few survivors all claim, 'But I looked and the road was clear'.
The common factor was the 'look angle', diagonally rather than directly through the glass. That gave just enough delay to be dangerous...
The effect tamed, spin-offs included panels with staggered delays for street-lighting, mirrors that let you see your back when you turn etc etc...
IIRC, the incinerator torch was a Larry Niven, 'Gil the ARM' tale, involving a 'time accelerator' device and drug-dealers peddling insulin...
I challenge this.
Glass does not slow light sufficiently to result in car accidents.
I'll posit that what they mean is the glass refracts the view, so that objects near the periphery are not visible when they should be. Their appearance in a driver's peripheral vision will be effectively delayed a few fractions of a second because of the refractive distortion.
{Cough}
This was SciFi, with 'one impossible thing', cunningly crafted from 100% 'Handwavium'.
In the cycle of 'Slow Light' tales, it did...
( IIRC, in the prequels, crash investigators did check those windscreens for a possible 'blind spot' due refractive index, found nothing amiss. I can't remember the precise circumstances that revealed the 'impossible' cause... )
FWIW, for very good reason, many, many real cars' subtly curved wing-mirrors are discreetly labelled, 'Objects seen in mirror are closer than they appear'. Sadly, takes but scant misjudgement to spawn disaster...
The fact that this was from a sci-fi book went right over my head.:oops:
Likes Nik_2213
The only one I knew existed, from Shaw's Slow Glass set, was whichever one was a murder mystery (?) which I read probably well over 40 years ago. The Niven reference also, though I now remember the story (a "locked room" mystery, IIRC).
And, that's what you get for cycling around in winter without accounting for windchill : brain freeze:eek:
Meanwhile back at the ranch (and let's not worry about who got the conversation wandering off :olduhh:), the OP's Wikipedia link on Slow Light leads to another article on research where they not only slowed light down but converted it into a matter stream.
Light stopped then converted to matter - Photonics.com 2007
Done at a couple billionths of a degree above absolute zero, so not coming to a picture window near you, anytime soon.
its not the speed of light which is the problem, but rather the frequency. Although frequency is kinda speed from a certain point of view, i am talking about the physical speed of light from one star to another star. think about it like this. 1 second of sunlight is not much fuel for a solar panel. and that is a cubic volume of light that is many miles long. yet your battery is probably 1 foot long. the energy of light is the frequency. you'd have to compress all that light into gamma radiation. this is unsafe.
As for Hau slowing down light to 38 mph, idk. Idk if the light got compressed into gamma radiation, or if red light hitting a camera at 38 mph would still look like red light. The other thing is the photon 2d density. for instance shining a flashlight, the flashlight rays are moving forward, but what is the 2d density from ray to ray. i think that is found by lumens, how bright can bright get. Sunlight is top tier in terms of that, hurts the eyes similar to looking at a laser. the maximum density may not be much more than the best lasers money can buy, but I am not sure maybe lasers can have more lumens. could also be the radiant flux. radiant flux refers to all wavelengths, lumens refers to human ocular wavelength reception. someone made a solar panel that has response to all of the radiant flux of the solar spectrum.
https://www.extremetech.com/extreme/252295-layered-solar-cell-can-capture-wavelengths-solar-spectrum
"It is mostly visible light that heats solar panels but there is some contribution from near and shortwave infrared."
this will change in the future with better solar panels being made.
no. probably we will have portable fusion reactors before using actual photons as batteries. the sun is a fusion reactor anyway.
