Cracking the Code: Unraveling a Cryptic Sequence
  • Thread starter Werg22
  • Tags
    Sequence
In summary, the conversation revolved around finding the next number in a sequence where the denominator is 12 and the numerator follows a certain pattern. The conversation also mentioned that the denominator could possibly be a multiple of 12 and any number not divisible by 2, 5, or 7. Ultimately, the conclusion was made that the 10th number in the sequence is 5 and the 100th number cannot be determined without more information.
Werg22
1,431
Here's something I thought of the other night:
0, 1, 1, 1, 1, 5, 1, 7, 2, *, ?
You don't need to know what * is :smile:.
Numerators when a fraction is simplified and the denominator is 12, starting with 0.
0/12=0 (0)
1/12 (1)
2/12 = 1/6 (1)
3/12 = 1/4 (1)
4/12 = 1/3 (1)
5/12 (5)
6/12 = 1/2 (1)
7/12 (7)
8/12 = 2/3 (2)
9/12 = 3/4 (3) <---- That's the next one
10/12=5/6 (5) <--- 5 is the one you're asking for
The 100th number in your sequence:
99/12 = 33/4 (33) Hence, you're right, I didn't need to know the 10th term.
Actually drpizza,
It's not necessarily 12. All you know is that 2^2*3 factors into the denominator, and 5, 7 and 2^3 don't. It could be 12*a, where a is any number not dividable by 2, 5 or 7. So you can't say what either the 10th or 100th terms are.
But congratulations nonetheless :smile:
Related to Cracking the Code: Unraveling a Cryptic Sequence
1. What is a sequence?
A sequence is a list of numbers or objects that follow a specific pattern or rule. Each term in the sequence is called a "term" and is identified by its position in the sequence.
2. How do you solve a sequence?
To solve a sequence, you must first identify the pattern or rule that the sequence follows. This can be done by examining the numbers and looking for commonalities or differences between them. Once the pattern is identified, you can use it to determine the missing terms in the sequence.
3. Can a sequence have more than one solution?
Yes, a sequence can have multiple solutions depending on the pattern or rule that is being used to generate the sequence. Some patterns may have more than one possible solution, while others may have a unique solution.
4. What are some common types of sequences?
Some common types of sequences include arithmetic sequences, where each term is found by adding a constant number to the previous term, and geometric sequences, where each term is found by multiplying the previous term by a constant number. Other types include Fibonacci sequences, prime number sequences, and alternating sequences.
5. How are sequences used in science?
Sequences are used in science to model and predict patterns in data. They can be used to represent biological, chemical, or physical processes, and can help scientists make predictions and draw conclusions about these processes. Sequences are also used in computer science and data analysis to organize and analyze large amounts of data.
  • Science and Math Textbooks
  • Precalculus Mathematics Homework Help
  • Biology and Medical
